LCD 19" BENQ T905 problems
  • manthi
    • Feb 2014
    • 39
    • canada
    #161
    Re: LCD 19" BENQ T905 problems
    ok thanks guys, now i need to get some equipment and spare parts
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      #162
      Originally posted by manthi
      so
      q808 and q809 give me reading of
      leg1 to leg 2 03.4
      leg1 to leg 3 03.0
      leg2 to leg 3 00.8
      q815 and q816
      leg1 to leg 2 1
      leg1 to leg 3 1
      leg2 to leg 3 1
      q805 and q812
      leg1 to leg 2 1
      leg1 to leg 3 1
      leg2 to leg 3 1
      so if i understand this correctly, my pico fuse pf801 is dead so are q808 q809
      and c826 has a broken soldering ,
      am i right, what else?
      You dont actually say what your meter was set on if 200ohms then 808 and 809 are off but assuming the "1" is on the left of the meter screen indicating over scale then q815 q816 q805 and q812 are good.
      If you are ordering get at least 2 extra. As already said it best to resolder ALL the high voltage joints - suggest remove as much of the old solder as you can and replace with fresh leaded solder.
      • manthi
        • Feb 2014
        • 39
        • canada
        #163
        yes it was set at 200 ohm.
        when you say [resolder ALL the high voltage joints ] do you mean the 4 inverter transformers t801-802-803-804?
        i am going to practice soldering on a scrapped board, and see how it goes.
        what material should i buy?
        http://www.canadiantire.ca/en/tools-...soldering.html
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #164
          Have you not read this thread it is mentioned over and over again
          Recently post 145 and 153
          • manthi
            • Feb 2014
            • 39
            • canada
            #165
            yes i read the entire thread, but for a novice like me, all those name transformer/inverter/caps/mosfet/capacitor diode..etc it get confusing.
            it is easier to understand if for exemple you say check pf801
            or resolder c824 c826 , then i know what you are talking about,
            anyways no matter what, all of you are of a great help, i sure couldn't fix that screen without your help
            • manthi
              • Feb 2014
              • 39
              • canada
              #166
              i bought a 25w weller iron,
              i removed pf801, it is dead
              removed q808 q809, one is dead but the other one looks good, when test it i get same result than q815 q816 (over range)
              i resolded the c826 leg,
              now i need to buy the 3a 125v fuse and the c5707 , couldn't find them at my local store, so i am going to order them from ebay,
              so it's going to take at least 2 weeks to arrive
              i will post an update
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #167
                You should replace the 5705s in pairs even if one is ok it is likely to go when paired with a new one. That is why I said order extras.
                2 weeks will give you lots of time to practice soldering and learn what the parts
                are called. We cant always see the numbers
                You REALLY do need to resolder ALL if you dont the 5707s will blow within a week
                (often quicker)
                • manthi
                  • Feb 2014
                  • 39
                  • canada
                  #168
                  i ordered a kit 4x c5707 2x fu9024n 1x 3a 125v fuse,
                  so it should be enough to replace my parts even if i damage one or two, the fuse is the only piece i don't have any spare, but my local store has it (the only part he has actually).
                  so time to practice now
                  • manthi
                    • Feb 2014
                    • 39
                    • canada
                    #169
                    hey looks like it's working.
                    i replaced the 2 c5707 and the pico fuse, and the problem is gone.
                    but now i have the most challenging part to do, if i want to do a proper job
                    Originally posted by Krankshaft
                    My standard operating procedure with these monitors is:
                    • Replace all of the secondary caps.
                    • Desolder all 4 inverter transformers legs and reflow them with new solder.
                    • Desolder all 4 transistors and the polyester caps (between the transistors) and inductors (nearby the transistors) for the inverter and reflow them.
                    • Check the rest of the board over with a magnifier for other bad joints.
                    If you haven't done all 4 steps in the list you will have a repeat failure.
                    since soldering is not my specialty, i am afraid that by trying to unsolder and redo all of the above steps, i might to more bad than good.
                    if i look at Capullaco story i think that is what happen to him
                    he bite off more than he could chew, and ended up with a big spark, and a dead lcd.
                    what do you think i should do the required steps and risk a total failure, or take a chance and leave the job as is (2 new c5707 1 picofuse and resolded polyester caps)
                    and a BIG THANKS to all the people that contributed to this thread, it is always fun to learn new things, in the end, it cost me more than buying a used lcd, but learning something knew is priceless
                    • R_J
                      • Jun 2012
                      • 9606
                      I just repaired a Dell E173FPb (Benq board) that had one shorted 2sc5707, and the cause was poor solder connections on components in the inverter, (transformer and cap. c735) plus other misc. poor connections. check the connections with a magnifier, I use an old eye piece from an old camcorder, but any magnifier will help, just look for what looks like a small dark circle around the components lead where it is soldered, and just resolder it. They will look something like this more or less
                      • adjnabi
                        • Mar 2015
                        • 1
                        • Spain
                        #171
                        Hello everyone
                        First say that I am from Spain and sorry for my English , I am using google translator.
                        My monitor is a Benq T905 . Has the problem of two seconds and off . If I connect it to pc , I see the desktop and two seconds and off, after shotdown continuous green LED and shortly after passing yellow
                        With a multimeter checked
                        Picofuse (PF801*) = 0.04 ohms, ¿Is good?
                        Two C5707 = Bad
                        Two D10PF-06-6K036534 (Q812* - Q805*) = Bad
                        *See Photo
                        I have doubts:
                        ¿Where to buy or compatible D10PF-06-6K036534?, I do not find
                        What Picofuse buy considering that I live in Spain ( 220V ) ? This is good for me?--->Fuse3A 125V. Reading the post 99...Yes, I think so
                        First photo.....
                        Green star = Changed
                        Yellow star = Good
                        Red star = Bad
                        I will change the yellow and red stars , but any suggestions? (Also I will review welds as stated in the manual....A guide on how to troubleshoot 2 seconds to black)
                        Second photo....
                        Is the pic not find it anywhere , any equivalent ?
                        Wrote the best I could , thanks for your time and work. A greeting
                        • jetadm123
                          • 2169
                          #172
                          D10PF-06-6K036534 is probably:
                          std10pf06
                          • silverdr
                            • Apr 2016
                            • 1
                            • Poland
                            #173
                            Hello group, I've got the 48.L1J02.A02 board which blows fuses (the main 2A one) - I found one leaking capacitor (C605 - 100uF/450V) but this couldn't be shorting, could it? When removing it one leg simply fell away.. What else should I be looking at? I use this schematic. Things before the 4 diode Graetz rectifier are OK. I suspected the rectifier itself but it also seems OK. Right after the rectifier the best looking candidate seems the Q601. Is the STP7NK80ZFP "Power MOSFET" (on the schematic called Q601 - 2SK3264) a typical failure? How to check it. What the ohmmeter should show? Every bit of help appreciated.
                            • ohren
                              What problems could this blown cap cause in a Marantz SR5400?
                              by ohren
                              I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
                              R533 right below it in the photo is charred, but measures the correct value.
                              1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
                              10-21-2025, 09:02 AM
                            • Caspar
                              BENQ GW2780-T power board blown
                              by Caspar
                              Hi all, I am looking for some help in ID'ing some parts in an attempt to fix a power supply from a GW2780-T monitor. The power supply PN is 715G7300-P02-006-0V3R. I have been looking around for the PN and it appear the board was used by other OEMs as well (ASUS, Viewsonic). If anyone has a schematic, it would be helpful.
                              Quick look on the underside of the board, I can see:
                              -D905 is blown - ? value
                              -R920 is open - 1Ω ?W
                              -R927 is open - 20Ω ?W
                              On top side, I see:
                              -R931 open - 0.68Ω ?W
                              Metered short:
                              -P9NK65ZFP...
                              06-01-2022, 05:16 PM
                            • jean luc ferre
                              laptop hp g72 b52sf screen problems
                              by jean luc ferre
                              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                              06-07-2025, 03:27 PM
                            • drscoot
                              HP X360 convertible battery blown fuse error, not charging
                              by drscoot
                              HP Modelnumber: 14-dh0061nb​
                              This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                              The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                              I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                              And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                              All these 3 batteries are charging...
                              12-15-2023, 05:54 AM
                            • Hondaman
                              USB problems?
                              by Hondaman
                              Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                              (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                              I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                              08-12-2024, 03:26 PM
