the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4950
    • New Zealand
    #161
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by 370forlife
    Solytech was a textiles manufacturer who bought out Deer not too long ago.
    Surprised they didn't push for cotton-based PCBs to save cost... or maybe that's what they stuff the capacitors full of.
    -David VanHorn
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Originally posted by goodpsusearch
      TMP-ANS LC-A350ATX
      The good thing about this power supply is...... that it is not going to power a computer anymore
      Not worth of anything!
      It reminds me of those power supplies:
      https://www.badcaps.net/forum/showth...ier#post114292
      https://www.badcaps.net/forum/showth...ier#post199701
      From the build qulaity pictorial. One of the worst ATX PSU's I have seen in a while.
      I love how they dated the warranty from the time of manufacure (not the time of purchase). FAIL.
      sigpic
      (Insert witty quote here)
        It's quite fun to drop a ton of bricks on top of these. They usually work better afterwards.
        • c_hegge
          • Sep 2009
          • 5219
          Another cheap Sun Pro. At lest thios one does use DC-DC conversion from the 5V rail to generate the 3.3V. However, it still never managed more than about 73% efficiency on 230V at about 250W Load. I doubt it would even manage 70% in the US. At 350W, the efficiency was about 68% and it exploded after a few minutes.
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            #165
            How is this for gutless and fried?
            https://www.badcaps.net/forum/attach...1&d=1334112631
            Okay, I'll come clean - the PSU didn't come that stripped down (obviously ). This used to power my family's 400MHz Pentium II PC back in 1999-2001. The model number on the label will fool you that this in an L&C, but it's not (most likely J&C just labeled it as such). It actually used to look exactly like these (save for the different cap brands on mine)
            https://www.badcaps.net/forum/showth...ighlight=m-tec
            https://www.badcaps.net/forum/showthread.php?t=1178 (see post #1)
            Seems to go also by the names of M-tec, Meico, and Frontier.
            As you can see, even without me removing the components, it's a very crappy power supply. Fortunately, it was pretty good desoldering practice for me a few years back. Also, the components I took out of it helped me save a 17" CRT monitor, a 250W HiPro PSU, and a few other things. Will soon be using one of the schottky diodes from it to make the 12V rail of a 250W Bestec 12Z a little beefier.
            • lti
              • May 2011
              • 2547
              http://www.eevblog.com/forum/product...-modification/
              I don't see how that AC adapter was supposed to work without filter caps.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Haha, must have a lot of 60hz hum on the output! (when its working-if it even does work at all :P)
                Its so cheap that it doesn't even work for a millisecond xD
                Note the fake certification labels!
                Look at the comments for this product!
                http://www.amazon.com/Apple-iPhone-T...pr_product_top
                LOL at one of the comments, the person said it almost caught fire, and it made their phone go whacky, probably from loads of AC hum on the output.
                -Ben
                EDIT:
                another fried PS picture!
                http://www.magicbluesmoke.org/309/in...s-nv-psu-fails
                Muh-soggy-knee
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  umm, it did. there are 2 tiny lytics.
                  also, it might be a half bridge cemter tapped rectifier, which would produce 100hz of noise (based on the plug, looks to be a 250V 50HZ connector). The picture is too fuzzy to tell.
                  There still would be lots of noise, as those caps are probably too tiny for the job.
                  sigpic
                  • lti
                    • May 2011
                    • 2547
                    It looks like the cap on the lower left corner next to the USB connector is a filter cap, but the other cap is part of the oscillator. That looks like the single transistor oscillator that is used in most cheap adapters, but the power just goes through a single diode before going into the oscillator without a filter cap or current limiting resistor.
                    • pdavid
                      • Jan 2011
                      • 279
                      • Hungary
                      #170
                      Oh my... How did I miss this. The famous "Mrs. Varga and Co." psu. I just gutted one today to get the fuse and mag-amp choke.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        #171
                        That is actually a very interesting PCB. It is designed for both AT and ATX - i have both versions. All i can say it's a big mess of a PCB. The input diodes are 2A, no room for a bridge rectifier. You can't fit any input caps larger than 330u due to can size. And there's no input filtering whatsoever, not even the room for it. Crazy.
                        A working TV? How boring!
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          BRACE YOURSELVES, you may cry at how bad this PSU is..
                          Too lazy to label the popped caps but I'm sure you can spot them. All it was powering was an Athlon 64 x2 and a 6800GS. Efficiency = 64% Canicon caps (kill me now)
                          • b700029
                            Banned
                            • Sep 2010
                            • 640
                            #173
                            How many watts was on the label? Looks like 150-200W max.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4950
                              • New Zealand
                              #174
                              The heatsinks don't seem too bad though, and there are actually inductors in the output not just wire links - also it has a bridge rectifier. It's lame but it could be worse.
                              -David VanHorn
                                master hoarder
                                • May 2008
                                • 12170
                                • Bulgaria
                                #175
                                Makes me wonder what software they used for the top-side printing - it looks horrible. MS Paint maybe?
                                The MOSFET and 431 shunt regulator are also pretty useful. I was prototyping a circuit yesterday and needed some odd resistor values. Found most of them in the bag where I have the parts from that PSU.
                                The heat sinks aren't too bad either, especially the secondary one. Might use it in the headphone amp I'm going to build (0.o).
                                Funny how I find this PSU much more useful for the parts than if it was actually working and in one piece.
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  #176
                                  the 3rd pic asks a question after the fact!.
                                  • SuperDuty
                                    • Mar 2011
                                    • 299
                                    • France
                                    #177
                                    Delta Electronics power supply and control board from a Belinea 1925 S1W screen I found in the recycling center electronics section this afternoon :
                                    Main cap is Nichicon, ALL the bloated caps are CapXon. The screen is not even five years old according to the PCB build dates :/ Really bad caps.
                                    Replaced them all with with what I had on hand (including Fujyuu and other sh**) but mostly for test purposes, the screen works fine but makes an annoying buzzing sound. It's kinda weird since I replaced the two CapXon GL105°C on the power supply board with the exact same CapXon GL from another PSU, with the same ratings, but a bit older. I guess I should buy some new caps for this one.
                                    • SuperDuty
                                      • Mar 2011
                                      • 299
                                      • France
                                      #178
                                      Comparison of a two PSUs :
                                      On the left, a 145W AT (not sure, it has AT connectors but no switch like most AT PSUs) Astec power supply, from 1997, high quality components and very clean PCB.
                                      On the right, the infamous Heden PSX-A330U, supposedly 480W...problem ? U mad ?
                                      I got it in a case I bought in 2004 or 2005. I used this power supply with an Althon XP2200+, a K7S8X motherboard and a Radeon 9600 Pro for about five years with no problem. No filter, no PFC, a lot of missing components. I've stripped it and threw the rest to the trash.
                                      This is a famous french article explaining in details about how bad power supplies from this brand are : http://www.x86-secret.com/dossier-36...on_Noname.html
                                      Two weeks ago I decided to have a look at my computer power supplies. I had about 20 of them...I have about 10 left, I even found a DEER power supply ! It will be recycled soon.
                                        Heh, the lone Rubycon and Nichicon are fine -> but the rest are CrapXon so they bulge like anything else! I have replaced so many bulged CapXon they are down their with Fuhhhjyuuuuuu.
                                        • Pentium4
                                          CapXon Be Gone
                                          • Sep 2011
                                          • 3741
                                          It was labeled as a 550W...
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
