Working on this machine which has a few issues including a short in the lcd connector. Anyone where I can get a replacement? Its 30 pin and about 2cm in length. All the ones I've seen are macbook ones-must be using the wrong search term in Google. Thanks
Dell Inspiron 13 7306 lcd connector
Re: Dell Inspiron 13 7306 lcd connector
It looks like an ipex 30 pin LCD display connector. Somewhere on this forum I posted a list of compatible connectors (if it is the same as yours) - you can buy these from Digikey.
https://www.youtube.com/watch?v=Vonw9IWMMf0
Let me see if I can find the post so you can compare against the datasheet & dimensions.
Update:
Ok - found it
https://www.badcaps.net/forum/showth...highlight=ipex
JAE:
FI-X30SSLA-HF-R2500
https://www.digikey.ca/en/products/d...-R2500/3674236
Be sure to check the edge - to - edge size of the connector and the pin pitch for each connector pin.
Same as yours ?
They are certainly lower cost on Aliexpress.
Maybe like this one?
https://www.aliexpress.com/item/3295...82696085%22%7DLast edited by mon2; 10-27-2021, 10:31 AM.
Thanks for the prompt answer - I think I'll go with Aliexpress and see what turns up. I was looking for a gold body connector like you get in the macbooks! The lcd/lvds cable is not a flat ribbon cable - its like a macbook. Will that fit into the connector?Last edited by luckydip; 10-27-2021, 11:17 AM.
There are many on Aliexpress. Here is the a random gold one:
https://www.aliexpress.com/item/1005...44397711%22%7D
The one from Digikey is in a class of its own. Very well built but then again you are paying a much higher cost and is the original that others are cloning. Hope it works out for you.
Originally posted by mon2 View PostThere are many on Aliexpress. Here is the a random gold one:
From what I know...
pitch on the macbook LVDS 30 pin connectors = 0.5mm
pitch on the iMAC LVDS 30 pin connectors = 1.0mm
What is the edge to edge dimension in mm of your connector?
The connector on your Dell sure looks to be the same as the Macbook connectors @ 0.5mm pitch.Last edited by mon2; 10-27-2021, 01:57 PM.
With 0.5mm pin pitch, the 30 contacts will be 15mm edge-to-edge.
Suggest for you to order the macbook 30 pin connector and before removing the original, overlay the two connectors to confirm one last time.
Sure looks the same as the macbook connector.
Do watch the videos on youtube on how to replace this component. Lots of flux.
Originally posted by luckydip View PostThe macbook ones are too small, the pitch is different. I think I need something like this but finding it will be like a needle in a haystack
Originally posted by diif View Post
