I'm troubleshooting an issue with a laptop where it doesn't seem to want to charge the battery. The laptop will run off the battery alone and use/drain the battery normally in this situation, it will run off the AC adapter alone, and it will run with both charger and battery connected, but it doesn't seem to charge the battery under any circumstance.
At startup of the laptop, the following error message is displayed by Dell SupportAssist: "Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust the performance to match the power available." I disabled this alert in the BIOS. I know the adapter is of sufficient wattage and voltage as it matches that of the original factory charger which has since been lost (45W, 19.5V), so I think the laptop is just mad it's not official Dell. However, it should still be working.
In Windows 10, the battery icon in the lower right tray will say "plugged in" when hovered over, but never anything about charging. I used a free battery monitoring program (BatteryCare) to confirm that no charging of the battery is occurring. Periodically Dell Power Manager Lite will display a popup in windows similar to the startup warning about the adapter not being recognized, blah blah.
Info / Things I have tried:
1. I am on the latest applicable BIOS from Dell's site.
2. Many common "fixes" for non-charging batteries found on the internet such as: plugging in the laptop, turning it on, removing the battery, uninstalling the battery drivers from device manager, shutting down the laptop, leaving the battery out for several hours, reinserting the battery and turning the laptop back on.
3. Swapped out the DC charging port on laptop.
4. Tried a brand new battery.
5. Tried a brand new 65W charger (universal).
6. I even reset the Windows 10 installation... just in case...
It seems like from 3, 4 and 5 seem to rule out the battery, charging cable, or dc port being the issue...
Then I found these schematics:
https://www.badcaps.net/forum/attach...5&d=1517020862
(original post: https://www.badcaps.net/forum/showpo...7&postcount=13 )
And took some measurements of PJPDC1 and PBATT1:
PDPDC1 pins:
1. 0V
2. 0V
3. 3.39V
4. 0V
5. 19.5V
6. 19.5V
PBATT1 pins (no battery, charging cable only):
1. 0V
2. 0V
3. 0V
4. 3.32V
5. 3.34V
6. 3.34V
7. 0.05V
8. 0.05V
PBATT1 pins (battery inserted + charging cable):
1. 0V
2. 0V
3. 0V
4. 0V
5. 3.23V to 3.28V
6. 3.22V to 3.28V
7. 15.17V
8. 15.17V
I am admittedly not very familiar with reading electronic schematics, but am I understanding correctly that PBATT1 pins 7 and 8 SHOULD be 17.4V? Are my measurements indicating that the battery is not receiving sufficient voltage to charge, and thus not charging at all?
Sadly I'm at a bit of a loss for where to go from here... it seems like the problem should not be the battery, charger, or DC port. It seems the only culprit left would be the motherboard (or something on it), but the idea of spending $150+ on a new board and trashing this whole old board when the possible fix might be replacing a single chip for a few bucks is frustrating.
Thanks for reading and I appreciate any help/ideas/input!
PDPDC1 pins:
1. 0V
2. 0V
3. 3.39V
4. 0V
5. 19.5V
6. 19.5V
1. 0V
2. 0V
3. 0V
4. 3.32V
5. 3.34V
6. 3.34V
7. 0.05V
8. 0.05V
1. 0V
2. 0V
3. 0V
4. 0V
5. 3.23V to 3.28V
6. 3.22V to 3.28V
7. 15.17V
8. 15.17V
