Hi everyone
I replaced a battery fpc connector on an iPhone X. The process went well and the connector is connected securely. However, the iPhone is not charging. It powers on, however it does not show the lightning bolt when plugged in and the battery percentage is at a constant 0%. It was charging fine before the replacement. It still, however, makes the charging sound when it is plugged in and connects to a computer fine. What should I do? What can be causing this?
Also, I have attached a picture, please can some help identity what these two components are and what purpose they serve. I have circled the two components in red.
Thank you!
Thank you!
