Asus ROG GL502VM G502VM Bios
    HI,
    Looking for bios image for the GL502VM (NOT the GL502VMK).
    Also, I'm a bit puzzled, there are 3 serial flash chips on this motherboard. Which one(s) are the bios?
    Re: Asus ROG GL502VM G502VM Bios
    Mainboard name, and revision
      GL502VM
      Rev 2.0
        try this
          Thank, I will do try.
          Onlly one chip is 64Mb so no confusion after all.
          Any idea what are the other two 8Mb chips? ... just curious.
            Try to replace only W25Q64 , if not , let me know to search for all
            tell me the name of other 2 cip
              The two other chips are W25Q80.
              One of your files was the correct bios file. Thank you!
              But I still have weird blue screens in Windows 10. On the other hand, Ubuntu seems to run without problems. Will try to reinstall Win10.
              J.
                See if the hard drive operating system is legacy or uefi ,
                  Originally posted by JLCurve View Post
                  HI,
                  hey was just wondering what number(in your photo) was the correct chip
                    Is it possible to get a dump of the W25Q80. Sorry if I'm necroing a dead thread.
                      i need accurate bios GL502vm rev 2.1
                      but i have an issue display driver did not install.......
                      i have try many time ..
                      zash
                        Angel_boy, thanks! Working bin files.
                          tanks! the ver GL502VM REV 2.1.zip have restore my bricked gl502vm.
                          very nice forum
                            I do confirm that GL502VM REV2.1 is ok ; it save my laptop as wel . Thanks
                              Hello, I hope you can help me, I am presented with a keyboard problem on my computer, this is a GL502VM and it has the Bios driver GL502VMK.308 installed, I try to install the bios that I downloaded from this forum but I do not have the option available in the BIOS ez flash 3 utility (it is off, it does not appear highlighted), I try to install it by the asus driver installer for windows 10 and it tells me that it is not compatible (it recognizes the GL502VMK> 308) and it does not let me go to an older driver How do I install the correct driver? Thank you
                                HELLO I search a full dump bios for G502VM With motherboard v2.0
                                (with ch341A programer spi) with backlight keyboard and me firmware please . (8mb)
                                  [QUOTE=ashefr10;1198541]HELLO I search a full dump bios for G502VM With motherboard v2.0
                                  Try this
                                    [QUOTE=binoyroy;1198591]
                                    Try this
                                    hello, thank you this bios works the ME part no longer has the error at startup but I do not have the backlight of the keyboard
                                    backlight keyboard not work
                                      I need a complete bios where the backlight works as well as the ME part
                                        try.this..
                                        https://www.badcaps.net/forum/showthread.php?t=69782
