Dell 3780 EDI73 LA-G711P bios
    Bios is corrupted od Dell 3780 motherboard EDI73 LA-G711P rev0.3.
    I tryed to put some bios dump from internet, with them laptop turns on, and with delay gives picture, but there is no service tag and other numbers. Because I bought laptop without bottom cover, i dnt know how to find service tag. Is someone have these problem?
    I will update my original bios, so someone can try to repair them:
    Re: Dell 3780 EDI73 LA-G711P bios
    try..
      try and report
        Originally posted by Claudiomfa View Post
        try and report
        Thanks, I tryed. Laptop wont turn on at all, no led diode, nothing.
          I tried to put his original bios with which he turned on and off after a few seconds, and now he won't turn on at all with that bios. This leads me to conclude that I have bad bios reading. That's also a reason why the bios you sent me don't turn on the laptop at all.
          Otherwise, I always read the bios twice, compare them with each other, and if they are the same, that's it. This time, when I tried the second reading, I accidentally entered the erase command, so I was left with only one dump that was not verified, and which turned out to be poorly read.
          My question is: Can someone fix that bios or use data like service tag and other from it, or is there any version that can work on any laptop, such as clear me.
            try this file
              try this file
              It will not turn on...
                try..
                  Originally posted by peste View Post
                  try..
                  It works
                  Sorry for writing the result after so much time, I only found time last night to write in the dump you sent me.
                  When it turns on, it seems to me that it automatically turns it off and then on again, which is why there is a slight delay before it turns on the screen.
                  Is that service tag written in that bios dump its original?
                    try..
                    Perfect! Working 100%
                    Which version of CSME System Tool did you use to edit de ME of this bios? I tried all of versions that I found and can´t open this bios!
                    If you can Clean the ME of this bios, I would be very greatful! It´s working but it lasts much time to show video.
                    Thanks!
                      Thanks!
                      use the ME Analyzer program here .... here you have everything you need ..
                      https://www.badcaps.net/forum/showthread.php?t=88533
                        Great! Thank you very much!
                          Bios 100% ok
                            use the me analyzer program here .... Here you have everything you need ..
                            please repost the dump file old looks corrupted.
                              Corrupted? What makes you think so? The file is OK.
                              Become a Badcaps supporter
                              Thanks to all supporters.​
                                Originally posted by vesko356 View Post
                                corrupted? What makes you think so? The file is ok.
                                thanks
                                  unzip it and send me if not corrupted. I have tried all possible means.
                                  Update winrar or use 7-zip if you can`t extract the file
                                    Hello
                                    I have Dell Vostro / Inspiron 3570, it no post, voltages are present on cpu and gpu and they get warm. Just 2 amber led flash.
                                    if someone can fix please.
                                      Originally posted by CeeEee4 View Post
                                      Hello
                                      Off topic, this thread is for the 3780
                                        apologies, it is for Inspiron 3780 and Vostro 3580, both model names are in bios dump.
                                        I have Dell Vostro 3580 / Inspiron 3780, it no post, voltages are present on cpu and gpu and they get warm. Just 2 amber led flash.
