I need to change mac address and serial number
    hi guys..
    i have two HP ProOne 600 G2 21.5-inch NonTouch All-in-One PC with same mac address and serial number so i want to change mac and serial..
    Itried to use HP DMI tool and HP BIOS Configuration Utility but not working
    always give me message access denied ... thanx all
    Re: I need to change mac address and serial number
    do you have to be logged on as admin or superuser or something ?
      yes bro i guess problem is manufacturing programming mode is in lock mode so i cant change anything...can i make changes on bios like serial number by hex editor and how?
        hello
        share your bios dump and i will cleare serial number for you and you will programming serial number after .
          It seems you get the message " manufacturing mode" in display. If so, then use the same bcu utility to unlock manufacturing mode. The file you get while putting the "getconfigutilty" has somewhere locked/unlocked mentioned in it. You just need to select unlock and then use setconfig command. After that dmi tool will work.
          PS: If you are not getting lock /unlock option in bcu tool config file, then use a diffrent version of bcu tool. All version doesnt work on all mobos. So keep that in mind
            alreadly trierd many versions of config tool but same problem
              this current bios that i want to modify serial number or manufacturing programming mode turn to unlock
