here is a dump, I received it for my 640 g2 but I have another motherboard version, it was not good for me.
HP Probook 640 G2 bios dump
Re: Slow Start HP 640 G2 Probook - Bios
[QUOTE=GValdameri;967761]I tried to use the "Intel Easy Clean Me" program, but it doesn't recognize my notebook's bios.
It does not work,there are videos on youtube that show how to clean me.you must use flash image tool.Last edited by bachir2004; 06-13-2020, 01:30 PM.
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by peste View Posttry..
The LED on the numlock and capslock keys flashes 5 times
Attached is the updated bios that was working.
remove the bios chip from the motherboard before reading or writing..if you use the clip you may have errors..use the chip adapter..search the internet for video tutorials, depending on the programmer you have.
Originally posted by peste View Postremove the bios chip from the motherboard before reading or writing..if you use the clip you may have errors..use the chip adapter..search the internet for video tutorials, depending on the programmer you have.
try..
So I saved the new BIOS settings on the original chip.
I tested it with the two versions that you modified and with an older one that I had saved.
The notebook turned on, but the charging time is the same.
Made from the bios in the first post, and the update on the HP site.Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by peste View PostMade from the bios in the first post, and the update on the HP site.
It is stuck in the BIOS loading for 30 seconds and after you start to load the system.
Only a few times did it start quickly with the previous bios, but these were rare cases.
try this tooAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by peste View Posttry this too
I did the tests with these BIOS images, but it didn't work, the startup time is the same and ended up disabling some motherboard peripherals.
So I decided to leave the original configuration.
Thank you for your help.
