Aspire 7740
    Re: Aspire 7740
    Pin U82 gave 3.3v at first then 0v.
    Is it possible that I killed it? I was careful not to short anything but those pins are very close together.
      Re: Aspire 7740
      Checked U82 again
      Pin 8 0v & 0v
      Pin 16 19.3v & 19.3v
      Pin 17 0v & 0v
        Re: Aspire 7740
        That's why you're not checking the actual PINS, but closest components connected if applicable...
        If not, I have a pre-made probes from sewing needle & testing under microscope...
        Hope You didn't kill it...
        Try to clean it with IPA & toothbrush, it may help...
          Re: Aspire 7740
          Also check resistance of PIN8
            Re: Aspire 7740
            Yeah, might have killed it, just checked U19 again 0v all pins
            Cleanup time!
              Re: Aspire 7740
              Don't like the look of pin 8 anymore, I've flattened the solder with a bit too much pressure for the probe.
              Might touch my soldering iron to it.
                Re: Aspire 7740
                May be the case...If you got hot air station, use that one & good amount of flux...
                  Re: Aspire 7740
                  Yeah got hot air. Resistance @ pin 8 2.65 K Ohms
                    Re: Aspire 7740
                    sorry, going to walk away from this till later, got tons of work piling up. Back to it later this afternoon.
                    Thanks for all your help so far loser18, you're a star
                    Dave
                      Re: Aspire 7740
                      Hi Guys, had to give this up in the end. Refunded the client for the HDD & charger. (goodwill)
                      But thanks for all the help esp. loser18 for sticking with me.
                      Dave
