with macbook i reflow using 380-400° on my hot air station atten 8586 as macbook absorbe heat very much. ofcourse each soldering station has it's own temperature calibration.
making measure all around the board without a logic is no sense. this big thing with all 0 volt is lan filter..... useless to measure for now.
i asked for 2 measure on these 2 coils (inductor) in my previous post.
next report voltage on green zone.
total 2 measure+ 1 ground.
u should have on green spot (white fuse) 12.5 volt ;
3.42 on the other green marked area.
if u have 3.3 volt on coil, u have 12.5 volt on that green marked fuse, and if u have 3.35 or higher (not over 3.42) u can put a fan, some ram slot, lvds connector with lcd and short that circled 2 dot on mainboard with a wtezer (smc bypass) and see if macbook start normally.
before all that, make sure u understand that procedure right. shorting those 2 pins should make your macbook start, so put fan, ram ecc ecc and be carefull to not short anything else. put all component on a non conductive zone.
u can try with magsafe only,with battery only , and with both.
any throuble, ask before act.
hi
there on my Macbook pro no voltage on fuse and tune on pad (points)
Please advice me how i check further.( and near dc jack one fuse is giving voltage.)
