I have 2N2222A and TIP120 on hand, assuming my 2N2222As i got on ebay are complaint with the spec they should be fine for this having a max of 0.5A sustained and i have a 1n5817 forward voltage should be 0.32v
This circuit is for me light strip i use for my keyboard, where my PICO will control the light based on a photocell and my magnetic switch MC-38 will pull the base of the transistor to 0v if my keyboard tray is pushed in all the way, meanwhile i have my override switch, the switch has 6 pins i would use 2 of each pair of 3
note that the GPIO pin i on the other end of a 25' (~7.6m) ethernet cable, i have 3.3, 5, and 12v Rails generated at this end of the ethernet cable, pico gets power via 25ft speaker wire with a micro usb plug on the end so vdrop on the main power lines is not a issue, vdrop on the 3.3v gpio pin may matter
