Asus G752VS rev 2.1 bios fix
    can someone please check the bios dump from my laptop and fix ME region for me? Thanks!
    Laptop was liquid damaged by coca cola and chipset was replaced.
    Now laptop sometimes turns on and works fine but sometimes only black screen..
    chip WINBOND 25q64
    Re: Asus G752VS rev 2.1 bios fix
    try..
      thanks, but not working only black screen
        try and report
          try..
            Claudiomfa: thanks but the same black screen only
            peste: same only black screen
              Do you wait some time when you power up laptop after flash a repaired bios? Normaly Asus after flash a repaired bios, power off and on a few times and power up ok.
              If none of above bios doesn´t work, I think that you have hardware issues.
                Yes I wait some time , try turn off and on few times, disconnect and connect CMOS battery ... but still Black screen only
                  check the motherboard ... it may still have traces of liquid. Remove DVD, HDD, keyboard, battery, WIFI..etc before turning on the laptop, maybe one of these components will cause problems..check voltages ..
