Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Originally posted by Joseph melville View Post
    do you still need the eeprom?
    might do . have other problems now as had accident with the led board and shorted the fet .
      Anyone, can help me with EEPROM, please?
      Looking for:
      WALKER WPS3219SM
      Mainboard: 17MB211S
      Chip: Winbond 25Q16JVSIQ
      Panel model: VES315WNDB-2D-N21
      Thank you in advance...
        Try (Toshiba). Main 17MB211S panel VES315WNDB-2D-N21
          Tryied this just now.
          Unfortunately, it doesn't work on this model... Thanks for trying to help me...
            Try this too. It is for 17MB211S panel VES315WNDS-2D-N21. If the image is returned I have the profile saved for fixing.
              Not working....
                I think there is another problem on the motherboard. Most often problems with dc-dc converters or processor. See also if the flash memory is powered by 3.3v.
                What are the symptoms of television?
                  Thanks for coming back to me.
                  Yes, there are 3.3v on the chip (EEPROM). 12v and 5v are on the board as well.
                  The red light is on and blinking 2 short times in intervals.
                  Backlight is working OK.
                    Don't confuse eeprom memory with flash memory !!!. They are different. See what memory you rewrote. The software is for flash memory, spi.
                      Sorry. I rewrote Winbond 25Q16JVSIQ (U135)
                        How does the defect manifest itself?
                          TV not turning ON. When you turn TV ON, RED light up and stay solid. When you push ON button, RED light blinks 2 times and stay solid. Then blinks 2 times again and stay solid. And does this all the time.
                          PS.: Backlight I checked with the mainboard from Panasonic TV. Backlight working, just can't turn ON the TV.
                            Heat the processor to 230 degrees for 1 minute and see what it does.
                            I think the motherboard has a hardware issue not a software one.
                            You can replace the memory with another new memory.
                              Heated for 1 min at 230 degrees. Nothing. Still the same problem...
                              Do you mean I have to replace Winbond 25Q16JVSIQ with new one?
                                Try. Rewritten. I have no other ideas.
                                  Thank you so much for your time, buddy
                                    Blaupunkt w40/58j-gb-fhcup-eu memory dump
                                    Hello, i need memory dump for this tv. the mather board t.msd309.8b 10304 and panel lta400hm07. thanks.
                                      hello everyone i just got this set in...37 inch Telefunken chassis... 40-1MS82D....I dont have the panel number...I need the dump for this board....thanks in advance
                                        Anyone at home
                                          Originally posted by Farasa View Post
                                          Anyone at home
                                          try this one
