HAVE TWO RX480 ASUS 8GB CARDS, ONE WORKS ONE DOES NOT oops caps, sorry
doesn't appear to be a short anywhere that i can tell and when powered up voltages get to the ram chips, giving the same values on each testing point on the pcb (around those chips)
booted into my hive machine to see what it makes of it and it shows no memory size, just memory type (probably pulled from bios chip)
have plugged it in as secondary in main pc and it boots without drivers but crashes BSOD if drivers are attempted to be used, if drivers are installed then after booting + showing post screen it displays a black screen (on my 1080ti as main [no onboard gpuchip] from then on. have snipped the gpu-z info.
will upload images in reply, it corrupted when it bsod so I must reboot again
Any help would be greatly appreciated as I am rather stumped on this one.
