I am trying to repair LG TV Model 55LW5000.
At plug in, the red LED blinks twice and then Blue LED lights for a second and then its all dead. Opened the back cover and measured the voltages at the power connector pins with all cables attached. Here are the results:
At pin 1 = 3.3V (PS-ON)
At pins 2,3,4 = 24V
At pins 9,10,11,12 = 3.5V (ST-BY)
At Pins 17,19,21 = 12V
At pin 18 = 0V (DRV-ON)
Main CAPS (4 of them) = 396V
Fuse F100= 120VAC, F101= 395VDC, F501=395VDC
All most all voltages present but the set does not go into standby? It looks the set is in 'RUN' mode but only dead!
Tests:
1- Disconnected Power supply connector. Plugged in the TV and measured ST-BY voltage on pins 9,10,11,12 = 3.5volts.
2. Jumped pin 9 to pin 1. Got PS-ON=3.3. Pins 17/19/21 = 12V and pins 2,3,4 = 24V. Also got 55V on backlight connectors.
3. Put in a second jumper from ST-BY to pin 18 (DRV-ON) and the backlight lit up. It suggests that individually the P/S board and inverter circuits are working.
4. T-CON is missing 12V input
Why DRV-ON is 0? No Supply to Inverter. What is reason that set goes into such a mode with just plug in and does not even go into standby?
Is it a firmware issue (bad EEPROM)?
Is it a MICOM (micro controller issue)? There is a reset option on the mainboard. How can it be reset?
There is an ERR OUT pin (pin 24) on PS connector. What is the purpose of it? Is it possible it is shutting the power supply with this two blink code.
Your input will be greatly appreciated. Thanks.
At pins 2,3,4 = 24V
Tests:
