Blomberg electric dryer - Need a replacement relay
    Re: Blomberg electric dryer - Need a replacement relay
    Originally posted by redwire View Post
    because children apparently climb in there for a wash or dry.
    They are not supposed to do things like that
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      I replaced the suspect relay with new, but it made no difference. The control board I ordered over a month ago is still out of stock. Any leads to an appliance parts salvage are welcome.
        have you pulled both relays out and tested them ? did you ohm the wires off the relay that go to the coil for proper resistance ? dryers are fairly straight forward - easy to repair.
        please post model #
        there's one on EBAY https://www.ebay.com/itm/194280574677
        marked washer but its a dryer control board that seems to be the one you need
        another one cheaper - https://www.ebay.com/itm/19381880177...Bk9SR6rHnKGFYQ
          did you check for any thermo-switches usually fitted as a final safety?
            Originally posted by ajshoe View Post
            there's one on eBay.
            Just Wow! Thanks for those links! I have been searching eBayzon and the web for over a month, but using Blomberg or the bare board number as search terms. Ordered on sight.
