hp elitebook 840 g4 need password unlock
    Re: 840 G4 6050A2854301-MB-AO1 bios lock
    THANK YOU.
    i FOUND THE SOLUTION:
    1- OPEN BIN FILE (16MB) using 'Hex Editor Neo'
    2- Save as a copy (for example 'cleared file.bin')
    (Dont modify backup, you can need it!!!)
    3- Replace all caracters between 00b76064 and 0009c56b by 'ΓΏ' or 'ff' in hexadecimal.
    4- Save again
    5- Flash rom circuit using the new file 'cleared file.bin'... Enjoy
      Originally posted by pipo7169 View Post
      hello
      please i need to clear pasword from hp 840 g4
      here my friend
      There are 10 types of people in the world. Those that understand binary and those that don't.
        hp elitebook 840 g4 need password unlock pls clean password
          Re: hp elitebook 840 g4 need password unlock
          this
            Originally posted by eikspaj View Post
            this
            thanx
              Can anyone tell me where the bios chip is on the HP Elitebook 840 G4 ? I've trawled through the service manual but can't see it referenced anywhere.
              Any help greatly appreciated.
                Did you even open up the laptop?
                There are 2 EEPROMs right next to the RTC battery. I think they are in WSON8 package on that model so unless you have a better way, they must be unsoldered to read/write.
                Anyway, the larger sized EEPROM is main bios. Probably 25Q128 written on it.
                  840 g4 chip is left near the bios battery (you can desolder or use old soic clip and cut off small plastic and hold on pads near chip
                    Perfect - thanks guys - I thought that was the one - I’m trying to use a clip but having a few problems - I’ll try again :-)
                      I've attached a picture of the chip ... does this look correct ?
                        I'm still on this - I can't get the SOIC clip to connect - what bits are you suggesting I cut off ?
                          BANNED
                            send me pm or conta**********ct********hen i show you pics
                            Pm’d - many thanks
                              send me pm or c**********************ow you pics
                              assistance is best done in public
                                If you want to read HP eeproms onboard with a clip you need to first unplug battery. Plug charger. Turn on laptop (go to F1 screen or bios, doesnt matter). Turn off laptop but keep charger plugged in. And now connect your clip and programmer. This way it almost always works fine.
                                But the one you sent a pic of is not correct. It is the other one with 128 written on it, not 64.
                                  I'm obviously new to all this and doing things the wrong way.
                                  The clip I'm trying to use is attached to a Raspberry PI - I thought that gave it all the power it needed ?
                                  In the hope of getting to the bios chip a bit better I've removed the motherboard.
                                  I've take pictures of the chip - I've no idea how to get a clip on this so contact is made correctly and unsure whether I can heat gun the chip off the board.
                                  Has anyone any experience of dealing with a similar chip ?
                                    Either you need to unsolder it or solder wires on the large pads around the chip.
                                      I managed to get it off the motherboard and flashed it using my Pi - unfortunately on reconnecting everything the laptop doesn't turn on - so I guess I've messed something up somewhere.
                                      I may give up.
                                      The power light (the main one on the switch) and the Caps Lock light go off then come on again in a cycle.
                                      I've had a hunt for whether this means something but am find mixed answers.
                                        It looks like you`ve knocked a part off the board.Check the traces as well for continuity,you might have cut through one of them.
                                          I'll have a look - there's a strong possibility the bios chip isn't sat quite in the right place - it just sits on top of the board rather then having legs going through it - so getting it in the right place seems like a bit of hit and miss...
