Lenovo Ideapd 5 15ITL05 Bios request
    Hello friens , i have a Lenovo Ideapd 5 15ITL05 wont charge battery, so i have these escenarys
    laptop with battery and charger plugged.... laptop power on but wont charge battery and no detect the ac adapter
    laptop only with ac adapter plugged .... laptop power on but wont charge battery and obvuisly no detect the battery
    laptop only with the battery plugged .... laptop power on but wont charge battery and obvuisly no detect the ac adapter
    does somebody has a working bios dump for this laptop, the MB is NM-D211 Rev 1.0
    Re: Lenovo Ideapd 5 15ITL05 Bios request
    Post your old BIOS backup, I will clean the ME Region to see if that helps. Do three readings.
      Have a dead unit in atm... someone has done work to it and have removed replaced the bios chips and the ec. so not sure the state of this dump... this system seams to have a dead smc chip. this board dose not have the video chip populated
      15ITL05 type 82fg
        15ITL05 type 82fg
        Hi friend. do you know, what chip is the main bios? this mb has 3 bios chips
          Usually the largest has the main bios, but do make a reading of all three, sometimes ec comes in 32MB and main in 32MB too. Someone here will figure them out. Best is to look at the schematics if you have them.
            From what i can tell the ub2 1mb one is for the usb3 retimer
            the uc704-uc703 8mb has the me and discriptor
            theuc702 16mb has the uefi
            depending on the fault i have had luck just doing the uefi 16mb chip but its usily best to do both the 16mb and the 8mb.
            ignore the 1mb unless having usbc problems.
            Im prity shure they combine the 8mb and 16mb chips.... i still dont know why they do it that way meby its cost cutting
              lenovo Flex 5-14ITL05 LC56-14T 203013-1 bios
              need to fix this bios plz
                Re: lenovo Flex 5-14ITL05 LC56-14T 203013-1 bios
                Serial number ? ,Model Type ?
                  Re: Lenovo IdeaPad Flex 5 14ITL05 bios dump
                  ok
                    Here's your new file, try it and let me know.
                    all donations are welcome,
                      no power not working i try an other one working but didnot read m2 hdd plz hellp old bin no data the oreginal bin
                        ok
                        As its a 5-15ITL05 and not a 5-14ITL05 your posts have been moved to a 5-15ITL05 thread.
                        Different Model Types can have different bios versions ! You can find which bios version you need by entering the laptop serial at Lenovo support,then looking at the bios update version number.You can check that number by looking at your own backup with a hex editor,and searching for the same FXCN .If you ask for more help in future it does save us time if you post the serial and/or the model type
                        try this one
                          Need Bios Lenovo Ideapad 15 15itl05
                          Hello everyone, i need a dump for this model if somebody have.
                          Mine laptop turn on, no fan spin, and black screen.
                          This is the dump
                            Re: Need Bios Lenovo Ideapad 15 15itl05
                            This is the dump
                            You should have another chip, it must be 16MB.
                              First dump is from Winbound chip , i made a dump from this now XM25QH128A.
                              I will attach dump here. Thanks
                                Here's your new files, try them and let me know.
                                  this is factory file 8m and 16m
                                  give me report please
                                    thanks your bios works , whit others no detec m2,... your bios factory ok thanks you
                                      hello i cant find the 16mb chip , can someone uplode a picture where is it?
                                      i found the 8mb chip but not the 16mb
                                        uc702
