sony vaio mbx - 270 schematic needed
    sony V170 MAINBOARD
    1P-0123200-6012
    MBX-270
    Re: sony vaio mbx - 270 schematic needed
    i really need it. please help
      did you fix the notebook? what happen?
        MBX-270 schema needed pls help
          Morning, please guidance friends, there may be a case of sony mbx-270 not display. I have done flasbios, external monitor test, internal monitor test (already 3 times change lcd), check flexibel (good) but still nil, 1.60 amper, test keyboard led capslock flame as well jg pairs of usb existing led flame ... Want to search lvds path but no scheme .. please guidance
            Hi
            It's not release schematic... here is how to convert enjoy.
            Techman1025
              Maybe fuse issue, in example F15 like on foxconn MBX-239 series.
              Try compare it the pin out of LVDS connector with other Foxconn's schematic. Possibly MBX-224 schematic.
              Link HD image MBX-239: https://***********/media/sony-pcg-6...-rev-1-1.1987/
                Hi
                First we need to know if backlight is on just no data showing? Or it completely black and if you hold a flash light to screen do you see anything . If you do it could me the lid switch also
                Techman1025
                  up for this.. also need this schematic thanks
                      Sir, i need a schematic sony vaio mbx-270
                      help me please
                        Originally posted by techman1025 View Post
                        Hi
                        Techman1025
                        tankyou tankyou tankyou
                          Walang avail yan bro... same here...
                            Hello, this is my first post in this forum
                            I am currently tinkering with this MBX-270 mainboard for a while now.. the GPU is dead, but i wonder why there is a empty socket near the PCH Chip and wifi card screw? is this for testing/debugging the GPU?
                              Sony vaio mbx-270
                              in need of schematic
                              V171 1P-0127J00-6011 REV 1.1 MBX-270
                              thanks
                                If no display but while you hold flash light to lcd and you see the display but no light. Just remove U38 and jumper pin in to out.
                                  i need mbx 270 schematic.
                                  now condition, only turns on 10 second immediately turns off again. eeprom and spi bios, repaired. convert dis to uma still not working.
                                  help me to solution....
                                    Dear all, as the last post by an Indonesian bro. I also have same issue with mbx 270. I turn in on it jumps to 0.08 amp stays on for almost 10 secs and turns off. 3.3v on ecrom but when I turn on it shows 0.60 volts on main bios instead of 3.3v. Couldnt find schematic Please suggest. Thanks
                                      Also same needed schematic to know…where is the location of the bios chip? An somebody help please?.
