Bios HP 840 g1 - 6050A2560201-MB-A03
    Hello everyone, i need a bios dump file for this notebook, The one i have is password protected. The one from hp's website is 8 MB and the chip is 16MB.
    Thank you
    Re: Need bios dump for HP elitebook 840 g1
    This is a full dump of 840 G1 bios and EC . L71 family MPM ^_^
      did'n work
      Хвала Аллаху, Господу миров
        backup old and try this
        Im Back... sort of...
          Thanx all
            Thanx Thanx all
              Got any for just the 840? Mine is not a 840 G1.
              Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
                thx all
                  Bios needed for HP Elitebook 840 G1 (6050A2559101-MB-A03)
                  I need bios for notebook HP Elitebook 840 G1 (6050A2559101-MB-A03)
                    Re: Bios needed for HP Elitebook 840 G1 (6050A2559101-MB-A03)
                    backup first...
                      Thanks, but it's not the right one. There is one Winbond W25Q128 chip and one Winbond W25W16 chip so the bioses are 16MB + 2MB. I found some bioses on ******* forum and flashed them but the result is the same.
                      When the power adapter is inserted into the motherboard, all the lights for power on are immediately lit up. There are 3.3V and 5V standby. There is also voltage on coils for the battery charge (2 battery terminals) and one coil has about 1V. No other coil on the board has voltage. No voltage for CPU and no voltage for GPU. When I long press the power button laptop won't turn off.
                      Is it maybe the problem with KBC? I will upload high res photo of the board to mediafire shortly...
                      Mediafire
                        try with this is
                        hoping to working for you
                          I tried it already. That is the same one I have downloaded from vlab. Not working
                            i found bios and schematic here
                            https://********/threads/hp-eliteboo...-mb-a03.16223/
                            i will need all files from this link thanks
                            and here another link
                            https://********/threads/hp-840-g1.14707/
                              Re: Bios and Schematic HP 840 g1 - 6050A2560201-MB-A03
                              any help ?
                              the caps and num, blinks 5 times
                                read and post your old bios, our friend will help you to get the right bios,
                                5 blink mean general system error.
                                  i dont have old bios, i try some dumps from internet. not working.
                                  if is bios error should blink other code
                                    you have one chip on the board try to reflow it carefully.
                                      try with this
                                        Please I need help
                                        how to dump bios for hp elitebook 840 g1 and can it remove lost password... thnx in advance
