Samsung ue40j5200aw - Replacing chip on the T-con board.
    Hey everyone!
    I've got this TV from friend. My guess is t-con board is faulty.
    If i connect/disconnect the flat cable on tcon board this is the image i get.
    https://imgur.com/tv5Z1Ju
    then the picture will go away.
    I've measured a few things on the board. I didnt find any short. There are voltages but i dont know if they are correct.
    There is a main chip CM2801C which i think is faulty.
    There is an eeprom i could programme it whit this:
    https://repairalltv.com/t-con-v400hj...00hj6-pe1-12v/
    but my board is a rev C7.
    Any thoughts?
    Re: Samsung ue40j5200aw - Replacing chip on the T-con board.
    Possibly , but more likely to be a display issue .
      You mean the LCD panel itself or those Ics on flex cable that attached to the panel?
        Don't waste time and money, it's 100% display panel issue at gate.drivers, them are embedded in the glass so no handling or access is possible, sell all the boards..
          Connect only one side at a time between the tcon and panel. If one side is good, so is your tcon.
            hey! i dont have much hope. Me too was suspecting that the lcd panel. i did order a chip for 3 buck and i will see. Thanks for your comment
              hi! if i disconnect one side of the t-con, the right side of the lcd panel goes white.
