Dell Latitude 7400 Bios Password
    Re: Dell Latitude 7400 Bios Password
    Can i get master password for G9CL793-8FC8
      Post your BIOS dump
        Can I get master password for 5KSD6D3-8FC8 please?
          post ur laptop bios backup
          or try
          https://bios-pw.org/
            Can you unlock my locked dump? 8FC8
              Become a Badcaps supporter
              Thanks to all supporters.
                Originally posted by Vesko356 View Post
                Laptop won't turn on, Just caps lock led on.
                What is the problem? Itry to reflash
                  Unfortunately your file not working. Original file is ok. I have tested it.
                    Should work, most probably you didn't programmed the chip properly (with verification) or didn't solder the chip as it should.
                    Try again.
                      Try again.
                      I reflashed the chip. Verified ok. Now working just high ventilation in factory mode which was confused me. Everything okay now. I'm happy that you erased the service tag region also. Very good work. Many thanks
                        where can I contact you?
                        I need to unlock a Dell Latitude 7400 Laptop.
                        59VBYY2-8FC8.
                        Please
                          Can anybody help with the bios admin password for my 7400?
                          System Number: 8SFJ1Z2-8FC8
                            59VBYY2-8FC8.
                            Please
                            You need to dump your bios chip content and reflashed the chip using patched content. Master password not available for free.
                              You need to dump your bios chip content and reflash the erased chip with patched content. Master password not available for free for these new 8FC8 suffix...
                                Hello i have a 8f8c -Latitud 7400 and reader CH341A any tutorial to read dump please ?
                                  There are plenty of demo videos available in the Youtube.
                                  https://www.youtube.com/watch?v=4qX2zihB6UE
                                  If you haven't purchased the programmer yet, i would highly recommend the upgraded version which has proper volt setting is available. Older black PCB one is not that reliable and need a hardware mode to make it compatible with some chips.
                                  https://www.youtube.com/watch?v=7_mnuuXyPiI
                                  In my experience, CH341A is a very reliable SPI programmer. What gave it a bad reputation is the usual way of using a clip to read the chip on board. This is a very unreliable method with any SPI programmer - even with costly programmers, reading and writing with the clip is a headache.. If you have good soldering skill, desoldering the chip and use a compatible SPI adapter is the best way. Otherwise you can try with the clip. In any case, you should read the chip multiple times and verify the checksum of all.
                                    Could someone please remove pass for me thanks in advance
                                      Removed
                                        Originally posted by hoaca388 View Post
                                        Removed
                                        Thanks mate any chance u could explain what u do to unlock them i have like 10 - 15 off them that i will need to do after i replaced screens on them
                                          please remove password from dump
                                          e7400
