MacBook Air A1465 820-3435-B
    Any body can help me for macbook air firmware password.
    Re: a1465 bios password
    read bios and post here, maybe i can help
    Im Back... sort of...
      just replace the efi problem solved
        and can you tell us how to do that ?
        thanks
          Hi upload original bios file I will remove it
          Techman1025
            Hi Techman1025
            I have a Question:
            With the Macbook EFI/Bios Bin dumps
            After reading the efi chip using a (MiniPro TL866) Programmer
            Im aware of Editing the bin using any Hex editor and removing the password
            but my Question is, Is there a way to (Remove the Serial Number) from the Bin file
            From each specific EMC model so they work on everyones macbook so people don't
            have to keep individually requesting Dumps ?
            I noticed that when I would order a Macbook EFI 8pin chip from China they would
            automatically work with "ANY" macbook with the same EMC regardless of the serial # or the same Bin file having to be written back
            Only to the same macbook that it was pulled out of.
            Here is a Picture I up loaded pinpointing the location I'm referring to
            Please let me know If you know from what section in the Bios Bin would need to be erased or how it would be done ?
              Originally posted by monkey1 View Post
              Hi Techman1025
              I have a Question:
              have to keep requesting Dumps ?
              he will need the .bin file
              My pc
              CPU : AMD PHENOM II x4 @ 3.5Ghz
              MB : ASUS M4A89TD PRO USB3
              RAM : Kingston ValueRAM 16gb DDR3
              PSU : Cooler Master 850W Silent Pro
              GPU : ATI Radeon HD 6850
                Hi first the correct way is to keep the original file intacted just remove it using a tool so you original me region stays intacted and all info if you use. a donor dump from another laptop it will have me region problems like fans running full speed random reboots and stut downs and more . the next way is to use a donor and merg the original file where me region is stored with the donor dump and just replace Ssn done then you do a clean install of OS so the cloud want reset password and in my case when using tool pram reset. Hope this help
                Techman1025
                  someone can tell us a metod to remove password from any apple dump ?
                    Hi yes you could just open text editor and replace SSN
                    Techman1025
                      Need Help for A1466 Apple MacBook Air 13" i7 1.7G EMC 2632 MID 2013
                      I need the original bin file for A1466 Apple MacBook Air 13" i7 1.7G EMC 2632 MID 2013 because when i tryed a bin file(for A1466 Apple MacBook Air 13" i5 1.3G EMC 2632 MID 2013) from my friend and it works but i have a problem with the trackpad and the keyboard they working in boot menu but not working after system start up
                      Please Help Me thank you
                        MacBook Air A1465 efi passoword remove
                        I need to remove password of this MacBook Air EFI
                        Model: A1465
                        main: 820-3208
                        attached binary file
                        thank you all
                          Re: MacBook Air A1465 efi passoword remove
                          Model: A1465
                          main: 820-3208
                          thank you all
                          Here you go
                              Remove password from this file plz
                                Re: MacBook Air A1465 820-3435-B
                                here is its
                                  thx a lot
                                    Can someone remove the EFI password on this dump Model A1465 EMC2924 TIA!
                                        Re: Can someone remove the EFI password on this dump Model A1465 EMC2924 TIA!
                                        Try this dump I`ve rebuild for you and post results...if doesn`t work, post the motherboard code and i will try to provide valid dump for you...
