Dell Latitude 7480 Bios Password
    Re: Dell Latitude 7480 Bios Password
    I have 1NF80X2-E7A8. Tried mentioned password generator. Received two passwords, held Ctrl and pressed Enter twice. Without success by both. User qwerty and qwertz. Used O instead of 0. Nothing helps.
    Any idea how to remove bios password ?
    Thanks in advance.
      @ok67
      • Post your generated passwords.
      • Count how many stars/asterisks are printed on the screen when you do the CTRL-ENTER-ENTER, there must be 16.
      • Upload a picture of the password screen. The master password works best at the System Password prompt “This computer system: #1NF80X2-E7A8, is protected by a password authentication system…”.
        Hello, I need help. Can someone clear me region in my dump? Thank you in advance.
          Originally posted by hoaca388 View Post
          https://beta.bios-pw.org/
          Change 6FF1 by BF97.
          hi,
          HX5QNQ2-E7A8
          i got this code
          and gave me these
          JI[91J16dJZj4bLk
          DGyq2GzzRGL5c7dJ
          not worked.
          do i need to change the last 4 digits to some magic number or is there some sequence/conversion for this?
          thanx in advance
          edit: when typed lower case, it gives different pair of codes
          e0eyPQN12M516N3R
          [Qrr2mkp4IQQyn4G
          also doesnt work.
            Originally posted by mysticusa View Post
            hi,
            HX5QNQ2-E7A8
            i got this code
            and gave me these
            JI[91J16dJZj4bLk
            DGyq2GzzRGL5c7dJ
            not worked.
            thanx in advance
            e0eyPQN12M516N3R
            [Qrr2mkp4IQQyn4G
            also doesnt work.
            Enter password with a removable keyboard, qwerty US layout ,usb 2.0
            Become a Badcaps supporter
            Thanks to all supporters.
              Originally posted by AAAC View Post
              @ok67
              Hi, started to collect information but fully unexpected the generated password was accepted. It worked !!!
              The point is, I was on a business trip and used laptop keyboard. At home I used external USB keyboard. It could be a reason why the password was not accepted. Now is everything fine.
              Thank !
                I have a dell 7480. code F401PH2-6FF1
                the WEBRctB5Uw8CbGZs on bios-pw.org doesn't work (I had tried it many times). pls, help me.
                  F401PH2-6FF1 change to F401PH2-BF97
                    Many thanks, it works. Could you explain to me How or where I could read about it?
                      From Pro members of this forum.
                        Evening, (well, it is here anyway) I'm a bit lost.
                        My system number is 16PPRQ2-6FF1
                        I've tried the number from bios-pw, I've changed the suffix to BF97 and tried that number too. neither work.
                        I don't have a US keyboard to try to enter it with that, is there anything else I can do to try and get rid of the pesky admin pasword?
                        Thanks in advance
                          Thanks in advance
                          I forgot to say I've tried to press both enter, left ctrl & entre & right ctrl & enter.
                          and I've confirmed that there are 16 *s on the password
                            Use right SHIFT key for uppercase
                            all donations are welcome,
                              Yes, yes, yes... Awwww shucks still no luck.
                              Thanks dude.
                                Thanks dude.
                                No, use Capslock for uppercase.
                                  He shoots, HE SCORES!!!
                                  Thanks for your help hoaca388, using Capslock for the upper case letters worked a treat.
                                  I used the password for the 6FF1 suffix and it worked the first time.
                                  Have a great afternoon (or whatever time of day it is in your timezone)
                                    Thanks dude.
                                    I had 3 with Nordic layout and only in that way it worked, using right Shift for uppercase.
                                      Dell Latitude 7480 Computrace
                                      Can somebody help me with computrace remove in dell 7480??
                                      I have dump!
                                        Also can somebody explain how to or what to edit in the dump? Many Many thanks
                                          Hi. insearch of password for DB9X6S2-BF97. The bios provided by https://beta.bios-pw.org/ doesn't work. help me please
