Xmc 25rh256cxiq bios chip
    Morning guys have anyone come across dis bios chip XMC 25RH256CXIQ it's not listed in the programmer and i hve the latest software and is not found cant be detected
    Re: Xmc 25rh256cxiq bios chip
    Try and replace the bios chip with another
    Make sure you use the one that have the same storage (mb) like the previous one
      morning sir thanks for ur feedback how can i check de chip when i dont hve the bios bin to programmed it with
        And your programmer model is what ?
          is TL866II programmer and i have downloaded the latest software but is still not found in it
            Choose a different chip instead and untick the Check-ID box .You might have to untick verify as well
            W25Q256FV @SOIC8
            If you want full support adding send them an email - http://www.autoelectric.cn/en/ContactUs.html
            EDIT: Support was added on Date : 3.05th.2022 http://www.autoelectric.cn/MiniPro/TL866II_List.txt
              Did anyone get a successful unlock with this chip or replaced it with another chip? My laptop was awarded by company and I got everything even it's own box
                Hello guys I also got a laptop with the XMC 25RH256CXIQ and the chip is not supported my programmer is RT809H. I have tried to add the chip manually but it can't read the firmware from the chip
                  if try to replace with another chip display will come but along with diffrent kind of issue we have seen this in dell 5420 model only xmc chip works fine try any other brand not work proper.
                    I have read the xmc 25rh256cxiq on my RT809H with no problems and wrote on it as well
                      i cant read it on RT809H and TL866II
                        Same problem with XGecu T56
                        all donations are welcome,
                        see the donate button below, at the bottom of the page, or
                        >>>>> click on this link to donate via PayPal. <<<<<
                        Doctrina est fructus dulcis, radicis amarae
                          Rt809f reads and writes without problem
                          enter correct id and it works ok
                            hi i have RT809F with last update 20221212 i cant read XMC25RH256CXIQ not in list i use MX25L25635E but dump is not working can you help mais plz
                              can you plz share Rt809f upload full software ?
                                https://www.badcaps.net/forum/showpo...40&postcount=2
                                1.1.1.3. RT809F
                                Supports I2C, SPI, LPC, FWH, VGA ISP.
                                Parallel interfaces support requires PEB-1 extension board and can be troublesome.
                                Support list: https://www.hklrf.com/24download/img/RT809F-List2.txt
                                Software: http://doc.ifix.net.cn/@rt809/ENGLISH.html
                                See post #13 to change the chip ID .
                                  I'm also unable to read out this chip using RT809F
                                  Can somebody tell how can you read out this chip?
                                  These are getting very common in Dell 11th gen laptops...
                                    Did you read post #13 ,maybe that will work.
                                      Thanks for help
                                        Confirmed.software needs to be restarted.
