Hp elitebook 840 g5 bios password
    There is a password in bios. can you help me please
    bios 32mb 25q256
    h*************g5.rar.html
    Re: Hp ellİtebook 840 g5 bİos password
      1
        bios 32mb 25q256
        https://dosya.co/xybze6qn0n9d/ellite...40_g5.rar.html
        rar pas . 1
        Try and leave feedback. Thanks to RethoricalCheese for the tool.
        Become a Badcaps supporter
        Thanks to all supporters.​
          thanks... vesko356
          not working 33mb.
            thanks... vesko356
            not working 33mb.
            What do you mean???
            Your dump is 32.0 MB (32768 KB), and the unlocked dump is exactly the same size.
              yes not working
              but RethoricalCheese for the tool working.
              tkans vesko
                yes not working
                tkans vesko
                RethoricalCheese is the guy created the tool for removing the password from the locked bios.
                So the file is OK? Everything working - no password anymore?
                  Bios elitebook 840 g5
                  I think i have read wrong my bios
                  pc is elitebook 840 g5
                  i have desolder MX25L25673G read by tl866IIplus
                  I have tried RethoricalCheese tool no succes
                  put back read file no succes
                  Somebody can help me please ?
                    Re: Bios elitebook 840 g5
                    try .. if it doesn't go read again and put the bios here ..
                      thx, but i solved with bios from internet
                        Hp elitebook 840 g5 bios clean
                        Hi guys
                        could anyone clean the bios password from this bin file, please?
                        Many thanks
                          Re: Hp elitebook 840 g5 bios clean
                          Originally posted by electroelef View Post
                          Hi guys
                          Many thanks
                          Try
                            works like a chaarm.
                            Thank you very much
                              HP Elitebook 840 G5 Admin Bios PW Removal
                              I've got an HP Elitebook 840 G5 laptop with admin bios password.
                              I have managed to get a dump of the bios (I think) and have tried all the tools I can find on this site (and others) but am not having any luck.
                              I have tried the "HP BIOS unlock tool" sticky'd in this forum but unable to get that to run at all.
                              I have tried using the HP BIOS Password Removal Tool, but I am not able to get the USB to boot on my laptop.
                              Can someone please remove the admin password for me?
                                Re: HP Elitebook 840 G5 Admin Bios PW Removal
                                Originally posted by AudioGuy88 View Post
                                you still have a bios chip on the board, post its contents ..
                                  Yes the chip is still on the board. I was able to solder wires to it and used the CH341 to get a dump of it.
                                  I don't understand what you mean by post its contents. I have posted the dump of the chip as an attachment to this post.
                                  Please clarify what you mean?
                                  This is my 2nd request, but will be first time I will be writing back to the chip.
                                    Please ignore this request. I have got it working.
                                    For some reason the HP Bios Unlock Tool, did not run on my computer.
                                    I ran it on a different computer, and it worked. It gave me an _unlcoked_ file, which I wrote back to the chip, and I am now able to get into the BIOS!
                                    Very happy. This is the first bios password removal I have done.
                                    Thanks to this site and all the contributors. You guys are doing a great thing!
                                      Hello
                                      Can somebody assist me as to which chip is to be read for removing the BIOS password on this model?
                                      I see here Winbond 25Q256JVEQ , is this the right one or not ? and how would you interface it without desoldering if you did it already?
                                      I have full package of RT809H with 52 pieces, but I am thinking of extending some wires directly from the SOP8 SOIC8 clipper to the pins on the board without desoldering.
                                      And lastly after making backup has somebody tried Mazif's tool to remove the password as the BIOS seems to be the same as in older models of Elitebooks?
                                      thanks
                                        Mazzif tool doesn't work since 8470p and later. My tool does but it varies on 840 G5 right now. Make copies of both chips and upload them to me.
                                        You could try soldering. If it doesn't work straight away, you could try removing batteries, attaching charger, then turning laptop on, go to F10 screen, turn laptop off again but do not remove charger. Attach programmer to wires and try to read. If this doesn't work aswell then remove charger and try again. If still nothing then you need to desolder them.
                                        But I suggest to invest in a hot air station like yihua 2008D or similar. They are cheap but quite good. Makes the job way easier.
