Psu pc Hp sff
    Psu pc Hp sff
    Hi everyone, I bought an adapter that should be used to connect a classic atx power supply on various hp sff pc types 6300 or 800g1, my doubt is the 6-pin P2 connector of the original hp power supply has connected the cables 1 2 3 4 while 5 and 6 are empty that instead of the adapter relative to p2 has connected 2 3 4 5 while 1 and 6 are empty, I don't know if it works because I can't find pins who can help me? Thanks anticipate.
    Re: Psu pc Hp sff
    I've worked on two of those HP SFFs, 6300's IIRC. One had a junk "replacepower" replacement, whose original caps failed after 6 months or so.
    The second had its original PS, but with tired/bulging caps. So I found an OEM PS for the first computer.
    Then, each one ended up with recapped OEM PSUs.
    Try to find pinouts of the OEM connectors, and see if any pins are redundant.
    Be especially certain that no pins/voltages are transposed to the wrong places, as this will (probably?) destroy the MB!
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
      Re: Psu pc Hp sff
      HP ATX PSU Pinouts https://pinoutguide.com/Power/#HP
        Re: Psu pc Hp sff
        I've seen dell SFF's with an atx wire moved from one place to another so SFF PSU would not turn on
        I moved to where it would be under ATX and it worked
          Re: Psu pc Hp sff
          try pinouts.ru
