Lenovo carbon X1 7th Gen pass
    Re: Lenovo carbon X1 7th Gen pass
    Does the Lenovo autopatcher not work for X1 Gen7?
      X1 Gen7
      Become a Badcaps supporter
      Thanks to all supporters.
        Originally posted by hoaca388 View Post
        X1 Gen7
        Each BIOS has a unique hardware signature. So what is this file?
          For unlock bios pasword.
          https://www.badcaps.net/forum/showthread.php?t=87588
            X1 Gen7
            Is this the DXE driver?
              Anybody know X1 carbon 7th gen jtag pin points?
                https://www.badcaps.net/forum/attach...3&d=1635949689
                  https://www.badcaps.net/forum/showpo...&postcount=204
                  no need to solder resistors as indicated by EvilBzyk, just move 10k resistor from pull-down to pull-up as is shown in picture.
                  all donations are welcome,
                    patched my bios
                      Originally posted by RAVI KARAN View Post
                      patched my bios
                      1- Patched file Write it to your chip and switch on laptop
                      2- When Thinkpad Logo Appear Press F1 or Enter Quickly
                      3- When you get password Screen Write 1234 then Press Enter
                      4- After You get HWID reply here your HWID i or someone will give you the unlock code
                      5- after unlock done shutdown and write your original file back
                        X1 Gen7
                        my 7th gen board has 16mb bios. patched this, please
                          I will update you next day..someone make patcher without asking machine id. is this possible
                              FOR X1 GEN 8
                                FOR X1 GEN 8
                                off topic, this thread for X1 7th Gen pass.Try the Autopatcher,if it doesn`t work start a new thread https://www.badcaps.net/forum/showthread.php?t=87588
                                  Please update the patch for me.
                                  X1 carbon gen 7
                                    X1 carbon gen 7
                                    I used Autopatcher. It gives results and there are no errors in the process. When I tried it, the screen didn't show up, only 1 continuous beep. Can someone give me further instructions. Here is my bios file.
                                      Hi, I need the patch for lenovo thinkpad x1 carbon 7th gen. I tried with autopatch 0.2 and old version no luck. You can help me patch
                                      here is :
                                        here is :
                                        You MUST post the laptop serial number
                                          Sorry here is :
                                          LENOVO X1 CARBON 7th generation
                                          serial number : PF-1X5Q7L
                                          TYPE : 20QD-000BUS
