TDK VYK3637 SMPS Power Supply
    Hi
    I've got a couple of these that need some attention.
    One powers up the machine but cuts out after a while.
    The other one doesn't power up at all.
    I'm sure it's only a couple of components causing it ,hopefully.
    I've recapped both of them. One worked after ,the other one didn't. I want to keep the repairs cheap as I'm trying to sell the machines they go into.
    Would anyone be able to give me a rough estimate on the cost.
    Im in the london area.
    Anyone have any recommendations for repairs in the the area.
    Ive contacted a couple already just waiting for a reply.
    Any experts on the machines they go into would be welcome too.
    They are Panasonic M11 AU62 and AU65.
    Re: TDK VYK3637 SMPS Power Supply
    Please post a picture of both sides of the circuit board in question we might be able to help you figure out what could be going on with it
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Here are some images of one of the power supplies.
      image uploader
        there is a tiny cap with black marker on top you didnt change - it's most vulnerable from heat
          Thanks I'll change that.
          What I really need is a tech to look them over and test them.
          See what's going on with them.
          Cheers.
            where are you located?
            shepards bush?
            totenham ct road?
            i am assuming your in the tv industry
              Hi
              Im in nw10. I'm trying to get them powering properly at least to sell them on.
              Thanks.
                harlsden / hanger lane?
                  Hi it's more Willesden.
                  I can't do much at the moment. I just wanted to find out if anyone could test them ,check them out. I doubt it's something major. Hoping it weren't too much to fix and that kind of thing.
                  Cheers.
                    i'll pm you later - i'm *very* close!
                    i could look at the psu's
                    dont know about the decks though - are they DigiBeta or something?
                      M11 they are.
                      Thanks.
                        Hi again.
                        I sold one of the MII machines. Buyer wanted to repair it himself.
                        I’m left with the one that doesn’t power up at all.
                        Cheers
                          I pulled 2 rectifiers (B92M) out so far to test them ,and got an extra reading on one of them. Any ideas.?
                            I removed another B92M and got the extra reading on that one too.
                              Hi
                              Does anyone know if there are replacements for the Low Loss Super High Speed Rectifier.....ESAB92M-02 200V 5A------ ESAB92M-02N 200V 5A------ ESAC92M-03 200V 10A
                              Cheers
