Macbook Air 1466 EMC2925 password
    Customer forgot efi password of Macbook Air 1466 EMC2925. So, please somebody remove efi password from attached dump.
    Re: Macbook Air 1466
    Here try this and reply.
      @imranromi
      reprogrammed dump attached by you. Machine won't turn, turns on with original dump.
        try this
        Im Back... sort of...
          @ala_borbe
          Thanks it worked.
          Can anyone teach me about how to remove password?
            Originally posted by dspok View Post
            @ala_borbe
            Thanks it worked.
            Any help ?
              Originally posted by Pascal Komlassan View Post
              Any help ?
              Use hexaeditor tool open the file and search SVS and fill with ff for everything there usually found two times in dump or
              Simple way compare the lock and unlock file in hexaeditor find the difference.
                Macbook Air A1466 EMC2925 EFI LOCK
                Good day to all. I am a newbie here. Can someone help me to remove the EFI password of this BIN file? My customer forgot the password of this. Thank you in advance. God Bless.
                  Re: Macbook Air A1466 EMC2925 EFI LOCK
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                    Read post #7 ,compare the differences between your backup and the unlocked one posted by Vesko https://mh-nexus.de/en/hxd/
                      Originally posted by Vesko356 View Post
                      Thank you so much. I will try this one... Hope it works..
                        Thank you sir...
                          Not working sir. It is still locked. Thank you sir. I appreciate this.
                            Re: Macbook Air 1466 EMC2925 password
                            Here you go.
                            I don't provide help for people using CH341A and a clip.
                              Originally posted by DanielDacko View Post
                              Here you go.
                              Thank you so much sir. I will try this and give feedback later
                                Here you go.
                                I flashed it already. Still the efi password is there... ��. Thanks a lot sir. Appreciate your work...
                                  Post screenshot.
                                    Post screenshot.
                                    This is the picture after i flash. Still have lock
                                      Post screenshot.
                                      I have tried another BIN file, which is posted in other thread. After the flash there is no efi password. But the problem it is stuck up in the apple logo. after 2 hours nothing happen. This is the picture sir...
                                        Use this, do PRAM rest after flashing
