Can I use these? GC/RS for RLP
    quick question
    recapping dell psu, missed capacitor spec, it's 3300 6.3 OSI RLP, there seems to be a pi coil in the circuit I would assume it's for 3.3v rail
    RLP
    0.38 ohms @ kHz, ripple 1655
    What I have on hand, is 3300 6.3v samxon GC and 3300 10v RS.
    RS 10v
    0.39 ohms @ 100kHZ, ripple 1863
    GC 6.3v
    0.11 ohms @ 100kHz, ripple 2885
    Which one should I use? or should I just order and wait 4 days?
    Re: Can I use these? GC/RS for RLP
    use the rs
      Originally posted by Mad_Professor View Post
      quick question
      RLP
      RS 10v
      GC 6.3v
      Either should work, GC has a very low impedance though. I'd pick RS.
      Popcorn.
        Thanks guys, I used the RS, I also ran into same thing with another PSU 2200uf 6.3 and after jazzie comment, I used a nichicon HE for that.
          RS is better for PSU indeed. But if the 3.3V rail is mag-amp regulated (which most are, unless you are dealing with some really cheapo PSU), the Samxon GC would have probably worked okay too, despite being quite low ESR.
