Re: Toshiba 46TL950 Greenlight turns on , backlight on , nothing on screen
i worte USB port 1, and fat 32 only no sense to try others not designed for this TL series.. even if the Tv function or defect ( dead ) when the 3 files played of the Set it will show upgrade picture on screen. you should put back any parts you soldered out. and Try other
USB stick ( blank with out any USB stick boot firmware ) some usb stick come with boot
BTW: also if you have SDCARD reader hub with sdcard 2 GB will work also if you formart it fat32 and insert the hub at USB port 1
