Macbook pro 820-2936-b problem with heating some parts
    Hello
    When my macbook was turned on, I noticed that it was heating up terribly u9480 and the temperature was a bit lower at u9390.
    What is the cause of this, where I could check.
    My macbook works normally I just have a problem with this temperature
    Macbook pro mid 2012
    820-2936 b
    Re: Macbook pro problem with heating some parts
    they are both related to displayport. check if its all clear in that connector -zone
      Thanks for the reply.
      I took out the motherboard, removed all the connectors and cleaned with alcohol. I didn't see any problem with the displayport. Maybe I needed to check something else, voltage or some resistance or maybe...
        u9480 must have a short on its output , according to Ti's docs it will current limit to ~1a.
        if it gets to hot it will shut itself down.
        with the power off what resistance is there between pin 1 of u9480 and ground
          I measured u9480-19,6KΩ
          Whether this is correct ?
            I'm coming back to this motherboard after a long time.
            In the meantime I replaced the U9480 q9425 and U9410 but I still have a very hot U9480.
            It can help ?
