Samsung NP300E5C bios dump needed
    Re: Samsung NP300E5C bios dump needed
    It will be also working for NP300E5C-A02PL laptop? Default BIOS version there is PO5RAJ. Where can I find it?
    -- EDIT
    Ah, I see now that I can extract BIOS file from Samsung executable program to update a BIOS. I will use this version of BIOS.
    Last edited by jcuryllo; 07-29-2016, 06:10 AM. Reason: Possibility of extract BIOS
      -- EDIT
      Ah, I see now that I can extract BIOS file from Samsung executable program to update a BIOS. I will use this version of BIOS.[/QUOTE]
      Hi, how do you do this? When I try to run the BIOSUpdate.exe file I get a message from Windows "This publisher has been blocked from running software on your machine"?
      Advice welcome!
        thank you so much
          Thanks kukasIII
            https://yadi.sk/d/kLiwPGFG3JPrZ8
              thanks evryone
                thanks a lot
                  Originally posted by seron View Post
                  Samsung NP300E5C bios son sürüm sağlam çalışıyor.
                  Link
                    Originally posted by kukasIII View Post
                    update ----
                    this bios is for np300e5x and not for np300e5c, there are some difference, missing secure boot. i will post the correct one.
                    the machine still work and post with this one, but i prefer to load the correct one.
                    Marca -samsung
                    Modelo -NP300E5C
                    Board -Scala3-15/17CRV
                    Bios -P03RAQ
                    https://www.badcaps.net/forum/attach...1&d=1405354294
                    This works OK. Thanks!
                      thankyou
                        thanksssssssssssssss
                          thank you!..its working.....
                            samsung La-8864t bios dump
                            Npc356e5c
                              I m looking for a BIOS dump file for NP300E5M-XF3BR,
                              thanks in advance
                                Hey.My model NP300E5C-S0tru motheboard BA41-01979A PTC. Will this dump work?I need help. I need a dump on my model. Thanks.
                                  Hi. I have a model NP300E5C-S0TRU Scala3-15/17CRV Rev1.2 BA41-01979A (PTC) This BIOS dump will work on my model? I need help. I need to dump the BIOS on my model. Thanks. Alexander.
                                    Hello Guys
                                    I need help with samsung NP300 series
                                    3 of them have a similar problem
                                    It seems like this problem happens when you change the cpu. but event if you restore the original CPU the problem remains.
                                    THe problem is mainly with the KEYBOARD
                                    all the keys are malfunctioning, but USB keyboard works ok.
                                    thank you in advance
                                      Hello
                                      please I need help with samsung NP300 series
                                      all the keys are malfunctioning the keys are not responding properly are this CPU change even after restoring the original CPU it happens on different internal keyboards, but USB keyboard works ok.
                                        tnks
                                          not ok for NP300E5A? i need bios update or backup for remove password.
