Samsung NP300E5C bios dump needed
    Re: Samsung NP300E5C bios dump needed
    Hello, I need BIOS for this model:
    Marca -samsung
    Modelo -NP300E5E
    Thanks!!!
    Saludos, Villa
      Marca -samsung
      Modelo -NP300E5E
      Thanks!!!
      https://www.badcaps.net/forum/showth...light=NP300E5E
        : Sevinmek:
        Originally posted by cyberhack View Post
        Here
        Electronicman
          thank you for sharing
            Here
            Works
              Here
              thnx bro
                Thanks for the bios!
                  Originally posted by kukasIII View Post
                  update ----
                  this bios is for np300e5x and not for np300e5c, there are some difference, missing secure boot. i will post the correct one.
                  the machine still work and post with this one, but i prefer to load the correct one.
                  Marca -samsung
                  Modelo -NP300E5C
                  Board -Scala3-15/17CRV
                  Bios -P03RAQ
                  https://www.badcaps.net/forum/attach...1&d=1405354294
                  Thx its worked but i disabled secure boot because its not booting from my drive. maybe its about my instalation
                    theanks
                      Re: NP300e5c Killing input FET after some time.
                      I just had this particular notebook here for repair, finally fixed (For everyone else having the same- or similar fault).
                      In my case it was a BIOS issue (or more likely EC FW, that comes with the update).
                      Symptoms were, that the notebook only ran on batty, gate voltage was too low on input MOSFETs.
                      so what I did:
                      • Bridge gate to enable input MOSFETs and charge the battery
                      • Update BIOS to latest version (attached, original from Samsung Update)
                      • Remove bridge
                      suddenly, gate voltage is correct and notebook runs on AC and Battery again.
                      Hope I could help. Cheers!
                        sasmsung np300e5c p04rap
                        can someone fix this bios please no display problem at fan at full speed
                          Re: sasmsung np300e5c p04rap
                          try..
                            thanks but still no display
                              Try this one,updated to P09 from the extracted updater at post #50 ,+ your DMI + clean ME .The platform ID is RAP https://www.badcaps.net/forum/showthread.php?t=88206
                                update ----
                                Marca -samsung
                                Modelo -NP300E5C
                                Bios -P03RAQ
                                Thanks bro. np300e5c-s0btr is working.
                                  It works, Thank you so much!
                                    Thanks for the bios bin file.
                                      Here
                                      perfect..thanks
