Hi does anyone know how to fix this or had this before I have checked tabs changed ribbons but still no different
55 inch vestel linsar with half line on the screen
Tags: None
Re: 55 inch vestel linsar with half line on the screen
the line at the 3/4 right side correct?
if you remove one ribbon on the effected side... did you got clear white screen or there also the line.. also you have on the effected side at the panel lower boards U ribbon cable did you check it... and what it will show if you disconnected it ?
