Hi everybody, I need your help please.
On friday, the projector worked for 4 hours without any issue.
On saturday, the projector worked for 20 minutes before I turned it off manually.
When I tried to restart it after a 30 minutes pause, it started as expected but after 2 minutes, the lamp goes out! Then the projector started to do its starting process again and again...
When the projector is totally cold, I got the normal start up process but after 2 minutes, the lamp goes out and the projector try to restart again and again...
The lamp bulb looks perfectly fine (it only has 100 hours usage time). Before this issue, the picture brightness was perfectly fine.
Please I need your help to troubleshoot this issue.
The service manual can be found here : https://elektrotanya.com/panasonic_p.../download.html
Thank you for your help.
