Logitech Z506 power supply
    Re: Logitech Z506 power supply
    Originally posted by HWLemfoerder View Post
    I just got a defective Z-506, the power supply is ok (hopefully
    long). On the amplifier board two of the SO-8 IC get hot when
    powering up the system.
    In the picture I marked both Ic with a red box.
    IC4 is a MC4558 (OpAmp).
    IC 402 is a LM385 (Reference Voltage?)
    Can someone make a scan or something similar from his
    board for me? The pinout of an LM385 voltage reference does
    not match the pads on the PCB. Some pins that are specified as
    not connected inside the LM385 data sheet are connected to
    resistors and capacitors on the board.
    Sometimes current reference I.Cs can get hot. As for the opamp I.C, possible internal short which made it became hot. Anyway, what was the problem with the speaker system in the first place? What are the symptoms? You have not mentioned that to begin with...
    Maybe LM385 is not right? Which IC is right?
    Perhaps someone has also a schematic for this amplifier?
    Thanks for the help ...
    Have not had much time to look thru the circuit yet, although the speaker is still with me (awaiting further repairs on that power amplifier I.C).
      maybe LM 358 Op Amp IC?
      "There is no shortcut to be successful. No pain, no gain."
      Best Regards
      Rudi
      Thank You
        OK, from the beginning ...
        When I got these z506, no sound was comming out of the speakers.
        Not even the background noise from the power supply (50Hz).
        Possibly muted ?
        First thought was the power supply. But that was ok. I replaced it
        by a external power supply unit with current limitation.
        I connected the right front speaker which has the power switch.
        When the volume control was completly turned to the left, the power
        consumption was 40mA. When turning it to the right, 230mA. Looking
        at the standby input of both STA540. Switching from 0V to 5V when
        turning volume control to the right.
        After that I checked the main volume control IC PT2325. Also the standby
        pin of that IC was changing from VCC to GND when turning right.
        But no voltage at the supply pins. I followed the wires on the PCB and
        got to the input of an 7812 TO-92 linear power regulator. Input voltage
        2,3V. Not very much.
        I supplied this pin external with 14V. Below that level, a +12V regulator
        won't work correctly. So this must be the right input voltage for this
        part of the system. Current consumption was 250mA (!)
        But now the system was working. I checked all channels of the PT2325 with
        a 1kHz signal and connected all speakers. Sound at every channel ...
        I broke up the power connection to every IC connected to this supply.
        All OP-AMP 4885 consume 2,5mA, the PTC325 30mA VCCA and 30mA VCCV.
        Can't tell if theses values are to high, no typical value was inside
        the datasheet.
        When I got to the LM385, it was hot ...
        I desoldered it and searched for an datasheet. I was confused about
        the function of this IC. So I took a look with an microscope.
        I was wrong, it is an LM358, as you can see with the attached images.
        But why are pin 1&2 short cut ? OK, could be an voltage follower
        with low impedance. But why a resistor (R700) 10k at the output ?
        Where is the low impedance then ?
        Regards ...
          R700 may be isolation resistor which may be connected to another output of another circuit, you need to trace out where the other end of R700 is connected to.
            aha. i was right. it is quite common today to see op amp ic on audio amplifier since transistor based audio amplifier is more complicated than one single ic op amp. unfortunately, i don't understand how to troubleshoot audio amplifier.
            Best Regards
            Rudi
            Thank You
              With the LM358 op-amp removed, check what voltages you are getting to its power and input pins. Since this is a dual op-amp IC, also check (without power) if its second output (pin 7) is shorted to ground or any of the supply rails. If everything appears to be normal, it could be that it just died. Why ? I don't know. But I have seen a few LM358 die/overheat like that for no reason, and upon being replaced, the circuit worked fine again. At least 358 op-amps are really cheap and abundant. I don't think I've ever needed to buy any. Many PC motherboards will have one. I have quite a few junk ones, and they all have one. So check your parts box .
              Any 358 variant should do, no just ones with LM prefix.
                More update on that power supply. The power amplifier I.C finally arrived and put into place. At low volumes sounds fine. And then in just under a minute after cranking the volume at a little more than half (with a slow bass heavy song playing), the power supply blew again in same manner as it originally sent it! And that was just in stereo, only 2 channels used and have not used the 5.1 surround test yet...
                The same diode at the turn off snubber this time cracked in half rather than becoming shorted. The same two rectifier diodes also went shorted. And the main TOP258MN I.C is cracked in half again (can see that from the side this time). Could there be a weak link/component somewhere?
                  That snubber diode is the weak link. It must be replaced with a part rated 3A or more.
                  At this point i would just throw an EEEPC or Aspire One power adapter in there and call it a day.
                  A working TV? How boring!
                    Unfortunately its not that FR207 diode that keeps blowing up, but the 1N4007S diode. It got to a point where I decided to replace it with power diode. In the next iteration, I've checked carefully, tested and replaced nearly all the discrete and SMD components as well (except for a few like the transformer). This time I could play it loud (volume almost full) in stereo. However as soon as I plug in all the speakers for the rear and center channels, the power supply went pop again! At this point, I'm beginning to guess that the transformer was the culprit (also found the primary coil measures almost nothing, about less than 0.3 ohm only)...
                    An interesting observation here, even though the audio source is stereo only however can hear the sounds not only at the front but also at the rear channels (no thanks to the heavy crosstalk). Add to that I've already replaced the power amplifier I.C also. In other words, all speakers are active even with only stereo music. That puts a much higher load on the underpowered (junk) power supply. My guess is that Logitech did not expect all speakers to be active together at the same time...
                    Thanks for the advice, I went this path after giving up on the original power supply. Found a nice 90W HP adapter and did some modifications to the original board so that I could mount it inside rather than left hanging outside.
                      Perhaps that 1N4007 diode really should be a FR107 or the like. AKA maybe the diode has too much switching losses.
                      But yeah, you replaced the PSU with that nice looking one, good job!
                      Were the panasonic capacitors on the output of that PSU when you took it apart? If so, good job HP/whomever manufactured that PSU!
                      Muh-soggy-knee
                        The original diode was an 1N4007 (weird choice for the snubber), in fact. Just keeps blowing up whenever the power supply fails. So I put an 1N5408 diode there, and you can see its kinda big and cannot fit on the top of the PCB thus soldered it to the bottom...
                        The first plan to make it sit but there were no secure places to hold down the new power supply board. Didn't like to use heat glue as I was afraid it may not hold nicely inside the very hot subwoofer enclosure environment. Thus I went for the screw on the heatsink, but that means it will be standing. Secured either side with double sided tape (pressed down firmly) to prevent it moving side to side. Two of the wires I kept short to make an anchor on either side.
                        Nopes, the original capacitor was Ltec LXY series (ultra low impedance). Just did not trust them at all, so decided to replace them with Panasonic FR series. Both are very close, in terms of ripple current (1820mA vs 1790mA) and ESR (0.023R vs 0.028R). Perhaps I should go for Panasonic FM series (ripple current handling of 2180mA and ESR of 0.019R for 680uF 25VDC) but did not have those in hand/stock at that moment...
                          "I'm beginning to guess that the transformer was the culprit (also found the primary coil measures almost nothing, about less than 0.3 ohm only" it has low resistance because you are measuring the DCR (DC resistance of the transformer winding), the transformer is made to be connected to high frequency switching DC by the SMPS, at those frequency, the impedance will be much higher than DC resistance. You have to use ringer tester and LCR to verify the transformer.
                            No. Transformers work on AC or pulsed DC - resistance as measured with a common multimeter on the ohms range (which works in DC) is irrelevant. Actually, the lower the resistance, the lower the losses in the wire.
                            Good job. That's kinda overkill tho - a 65W brick would have done the job just fine.
                            Indeed.
                              Aye, I know a LOPT/FBT tester would be required. I just did a quick measure after pulling it out and before relegating it to the garbage bin. Around 0.3 Ohm is probably the limit of my multimeter for DC resistances below 1 Ohm, has an error offset of around 0.2 Ohm to 0.3 Ohm (which is why I've mentioned it measures almost nothing).
                              I've also had a much smaller 64W Sony brick (output was 16V 4A), but I thought the HP adapter with higher power output would be better. Anyway, the Sony one was only half the size of the HP adapter and is actually smaller than the original Logitech one, thus that kinda worries me...
                                It seems odd they are using a general purpose diode and not a fast one there, I always saw diodes like FR107, HER103 etc used in those places. But maybe it's not the diode, and you have some other problem.
                                -David VanHorn
                                  Usually I would expect something like FR107 or UF4007 in those locations, instead of 1N4007. Anyway, I've seen normal diodes used in some switching power supplies before (as snubbers). As for the source of the problem, the only essential part that I did not replace was the transformer. The rest (including the zener diodes, optocoupler, capacitors, resistors, rectifier, etc) have been replaced. Did manage to get it to almost full volume in stereo (unlike previous brown out which happens at half the volume only), but the moment I had connected all the satellites for the rear and center channels then the power supply went kaput again...
                                    I agree.
                                    Fast recovery diodes are a much better choice in a snubber network. When the transistor goes off, you need something to conduct the energy from the inductive kickback fast. Otherwise, the voltage spike could be quite high. The lower the reverse recovery time, the faster the diode will clamp the spike. The capacitor-resistor parallel network is also important in terms of how high the voltage spike stays once the diode conducts.
                                      Hello guys,
                                      Just dropping some words.
                                      This topic help a lot. I was curious to know how this z-506 is inside.
                                      Mine version has a full range power supply, 110 to 240V an is a little different inside.
                                      I opened it to see the contents but was unable to take of the main sound board. It seems it is stuck with glue on the back. And the power supply board has two screws that i could not remove because I do not have a small tool to use inside the wood case.
                                      But I could measure th voltage the power supply is delivering to the sound board. I measured constant 16.5V with no sound and with sound.
                                      My goal is try to use this multimedia with a 12V batteries from a car (13.8 with engine on?). Maybe will I need a booster converter to step-up the 12V? If I have some time today, I will try put 12V direct to it and see if this can work.
                                      If I can de-stuck the sound board, I wil take some pictures and post here to help this topic with more info. Really, I searched A lot through google to find info like this....
                                      Bye
                                        It'll work on 12 volts but the power output will be a bit lower. With the engine on, alternator running you have around 14 volts which will do fine.
                                          Hi, me too have had issues with the PSU on this.
                                          I brought one of that well known auction site, said it was "brand new" came in a tatty box and to me looked like it had been used. Anyway i wernt to bothered if it was, thats if it worked anyway. Wouldnt power on at all so mailed the seller and they sent me a full replacement system and they have told me to keep this faulty one, bonus.
                                          So ive got this to tinker with and after reading through the whole of this thread i guess it was the psu. I couldnt see anything noticeable wrong with it and im more of a mechanic than an electrician so instead of attempting to sod about finding the fault/s and fixing the psu i was going to fit an old laptop charger ive got lying around.
                                          Ive got a dell 19v 3.4amp, will it do the job or is it overkill? i dont wanna go frying the thing.
                                          cheers
