toshiba 24d1434db firmware
    hi trying to repair a Toshiba 24" 24d1434db TV has the vestel 17mb95s-1 originally had a red/green flashing light bought a replacement board was ok for 3 months now I'm having same problem. found a couple of firmware files on the net got it working again but displays upside down dvd functions don't work can any one help me
    Re: toshiba 24d1434db firmware
    I have the eeprom dump from 24d1333db
    This is the black version of this TV. However you'd need a eeprom reader to programme the chip + reasonable soldering skills.
      Can you upload it mon ?
        Hi That would be helpful I have good soldering skills. also have a eeprom programmer. So I need to remove MX25L1606E. If you could attache the dump file I'll give it it ago
          see attached. let us know how you get on
            just to update i actually saved the file wrong its for model 24D1433DB
            im confident this will resolve your issues. The only difference between models is yours is white and the 1433 is black.
              Cheers matey will help alot of people
                Thanks bud I'll let you no how It goes
                  Copied dump file to eeprom a couple of times but made no difference display still upside down same problems.
                    Dam it the screen used must be a different panel than yours, can you not just flip the lcd over in the case lol ?
                      Maybe they sell upside-down wall mounts.
                        Tried flipping LCD panel no joy there. Lol yeah I'll just mount it upside down write Toshiba on with a marker pen.
                          Strange that didn't work.
                          For the record here's the panel sticker.
                            Have you got a picture of you panel sticker so we can see what lcd is used
                              Pics of my display
                                OK so that doesn't make any sense.
                                As I previously thought it's the same panel used.
                                  Service menu shows panel as 32" veswndl01
                                    I still have this TV, I use it for my microscope.
                                    I'll check the service menu tomrrow.
                                      Btw when programming the eeprom did you use a new chip?
                                        No I wiped then read it to make sure it was blank then programmed. Do I need a fresh chip ?
