Desktop EMachines ET1331G, AMD Athlon(tm) II X2 250u Processor
    Hi guys; is here anybody Computer pro, i have here an old computer Desktop EMachines ET1331G, AMD Athlon(tm) II X2 250u Processor .and i need to install a Linux distro, which one should i use, i tried Ubuntu 18.04 but it doesn't run good on it , Desktop
    Re: Desktop EMachines ET1331G, AMD Athlon(tm) II X2 250u Processor
    Solved;
    i had an extra HDD and i did a fresh install of Xubuntu 18.04 and use Firefox and it's got OK also disabled Java and it got even better,thanks
      Ive had good luck using Mint Linux 19 on older dual core AMD systems, if your GPU is week try the XFCE version or Ubuntu MATE is also a nice low resource version.
      My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
        Xubuntu is a good choice. I use Lubuntu.
        Version 20.04 will be coming out late April 2020.
        X/Lubuntu will run on 1GB DRAM, but 2GB is better with today's browser.
        --- begin sig file ---
        --- end sig file ---
          This machine should be able to take at least 4GB of RAM and up to 8GB, and this one has a pretty weak CPU, would highly benefit from an upgrade if it can take higher TDP (should be able to take at least 65W maybe even 95W). Then it should run pretty good.
            Thanks piernov, do you think this CPU can be upgraded?, i heard it can't?
              can i use any of these to upgrade?
              http://www.cpu-upgrade.com/CPUs/AMD/...I_X2/250u.html
              https://www.ebay.com/p/96871321?iid=...RoCK64QAvD_BwE
