Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 04-16-2021, 03:02 AM   #1
dicky96
Sun Seeker
dicky96's Avatar
City & State: Sunny Gran Canaria
My Country: Spain
Line Voltage: 220V 50Hz
Default Need to Replace small QFN very close to DIMM sockets - suggestions?
Hi guys
You can see the attached pic - the QFN is faulty and needs changing. It is closer than 1cm to the DIMM sockets and of course I must not damage these
So.... best suggestions and techniques please. Desolder and Resolder. I have some thoughts myself but don't want to distort the responses
dicky96 is offline   Reply With Quote
Old 04-16-2021, 05:25 AM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Nood to Replace small QFN very close to DIMM sockets - suggestions?
shield the sockets with tin-plate
i use old tuner covers.
and consider heating the underside first.
Old 04-16-2021, 07:05 AM   #3
diif
City & State: Midlands
My Country: England
You could Dremel the top off if you're worried about heat. I'd shield the ram socket with foil and kapton tape.
diif is offline   Reply With Quote
Old 04-16-2021, 06:53 PM   #4
megaraider
City & State: Porto
My Country: Portugal
I'm a: Hobbyist Tech
Default Re: Need to Replace small QFN very close to DIMM sockets - suggestions?
Worried about heat? Use a QFN soldering iron tip
... don't bother to buy one: that qfn ic is so small that your everyday soldering iron will be enough:
just make a solder bubble and drag it to the unused space (top left corner on the picture)
or live life to edge and throw it off by quickly flipping the motherboard upside down.
megaraider is offline   Reply With Quote
Old 04-16-2021, 07:09 PM   #5
petehall347
City & State: worcester
My Country: United Kingdom
try hot air and iron at same time . crank both up and do it as quick as possible .oh add low melting solder to speed things up .
Old 04-17-2021, 04:31 AM   #6
dicky96
Sun Seeker
dicky96's Avatar
My Country: Spain
@petehall
@megaraider
I normally add leaded solder to all the pins of an IC, or SMD cap/resistor before using hot air to desolder - It seems to help a alot, but I'm not sure how effective that would be on a QFN where most of the pads are underneath the IC
Are you suggesting if I add leaded solder as best I can then place a large tip (T12 BC3) to the top left corner of the QFN, hit Boost on the KSGER T12 and I can just lift it off with tweezers?
I can see that may work if, especially if I use my hot air preheater (Kada 853B) and a thermocouple to get that area of the board heated from below to around 100C first. Hmmm........... interesting.
Old 04-17-2021, 06:41 PM   #7
megaraider
City & State: Porto
Originally Posted by dicky96 View Post
@megaraider
I normally add leaded solder (...) a QFN where most of the pads are underneath the IC
Since it's a (very) small QFN IC package not only add leaded solder to the pins but also make a solder bubble covering all the IC.
Therefore, don't bother with the underneath, the leaded solder will reach there.
Yes, but again since the IC is so small using tweezers will cool the solder before you manage to grab it.
Instead use the soldering iron tip to drag it.
imo there's no need to add complexity to the procedure using a hot air preheater below the motherboard.
Old 04-18-2021, 03:21 AM   #8
dicky96
Sun Seeker
dicky96's Avatar
My Country: Spain
OK, thanks mate
I'll look for some small QFN on scrap boards to practice this method first. The 'solder bubble' method is something I already use with other SMD devices
Cheers
Rich
Follow me on YouTube
Learn Electronics Repair
Old 04-18-2021, 06:45 PM   #9
megaraider
City & State: Porto
You're welcome. Let us know how it went when done.
Old 04-21-2021, 07:35 AM   #10
miayotto
City & State: khakov
My Country: ukrain
Нужно залудить контакты сплавом розе или вуда если такового нет то свинцовым припоем .При условии что они открыты и пропаять их сначала паяльником с тонким жалом а потом феном .Использовать не активный флюс , каптоновый или алюминевый скотч ими закрыть пластмассовые детали чтобы вы не поплавили их случайно паяльником а тем более феном.Но учтите этот сплав используйте аккуратно им можно перепачькать всю плату. Для удаления используйте медную оплетку
miayotto is offline   Reply With Quote
Old 04-21-2021, 07:36 AM   #11
miayotto
My Country: ukrain
Сплав вуда или розе
Old 04-21-2021, 09:31 AM   #12
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
miayotto: English only in this forum please.
You can use Google translate if you need to translate something.
Badcaps.net Technical Forums 2003 - 2021
