PS3 not reading discs
    Howdy everyone.
    I have a PS3 CECHG03 which has troubles reading discs.
    It also used to get stuck on black screen while trying to connect to/install playstore, which I fixed by replacing the HDD.
    I have reflashed the firmware from USB, but that did not fix the disc problem.
    I tried the console with another two drives ( from ylod-ed consoles, so do not really know if the drives are fine, but the hell are the odds all drives to be dead??? ) but again no joy.
    When a disc is inserted, the blue light ( next to the power light ) flashes and then goes to solid blue, so I guess at least the motherboard knows there is a disc present in the drive.
    The closest thing to a working drive is getting the tracklist of an audio CD (with two of the drives ). It lists the tracks with their times, but doesn't play them ( after some time shows an error message - "bad data" or smthng ).
    Any ideas what might have gone wrong?
    Oh, I also switched the PSU because the original one was lil' bit noisy ( audible noisy, have not checked it on the scope though ).
    Re: PS3 not reading discs
    Here is a SM, page 18 is the connector on the MB
      you cant swap the drives, only the mechanicals.
      the drive boards have a serial that the console is locked to.
      did you clean the laser?
        Thanks for the reply, just came to update with the same conclusion .
        I've read previously that PS4 drives were "married" with the mainboards, tried searching about PS3, did not find anything so I thought PS3 was not affected...
        I run the original drive without the case and noticed it was not spinning the disc. Installed its board to one of the other drive mechanics and voila - works like a champ.
        So the initial problem was caused by faulty mechanics and simple drive switch does not work, but only adds more false symptoms.
          well the fat ps3's had a common problem,
          the laser sled did not like shocks - if you knocked the consol over or hit it really hard the laser had to be replaced.
          i suspect optics, either a lense or mirror breaking loose.
          i dont know if newer drives have the same issue.
            here is my run in with my PS3 not accepting DVD's anymore. https://www.badcaps.net/forum/showthread.php?t=62405
            Maybe it helps...
              Do yourself and your vision a huge favor and don't treat lasers lightly, I would never recommend powering on a blu ray drive wtihout its case unless you were wearing frequency-deleting eyeware designed around that laser.
              It's unlikely to blind yourself with a reflection from something as low powered, but you can never be too careful.
                there was a disc obstructing the beam.
