HP Chromebook 11 G5 developer mode
    I have a bunch of leftover chromebooks but right now they are unusable because they are in managed mode.
    Tried to access developer mode but no luck. It says that admin has disabled developer mode. Removing the write-protect screw and removing all power for a while doesn't clear this restriction.
    Has anybody enabled developer mode on this machine?
    Re: HP Chromebook 11 G5 developer mode
    Here is the bios dump. I am unable to disable admin restriction and changing SN doesn't affect enterprise enrollment aswell.
      can you not format it and install a fresh system ?
        Have you solved this please?
        I think that you should have disabled TPM as much as I am informed after changing the serial, because after changing the serial it should not be enrolled anymore
        Best regards
          No, still a bunch of them waiting.
          I don't really know what to do with chromebooks
            i have disabled the dev mode and enrollment
            program bios.
            first start esc refresh .
            ctrl -d
            and space
              I already solved it a few months ago. Just modified two bytes for it.
                Thanks for the hint
                  HI @RethoricalCheese, How?
                    Use RCUnlocker
                      Use RCUnlocker
                      Please i can't even find RCunlocker on Google.. I'm also in such hole, please help..
                      Thanks 👍
                        Go back one page and look at topic names @ top.
                          Hi All need bios dump HP Chromebook 11-v010nr IntelCeleron N3060 16GB eMMC 4GBRAM Motherboard
                          i attached backup bios
