Hi All,
I have an LED Light array that had a built-in AC-DC 24v 45 watt power supply. The power supply failed so I desoldered the LED Light array power input wires from the power supply and then screwed it into barrel connector jack (ends still tinned with the original solder).
This is the barrel connect or jack https://www.amazon.com/gp/product/B07Q6YMM6F/
Then I bought an external 24Volt/3Amp power brick (with same size barrel connector output) and plugged it in.
Everything works fine, except that the screw-in barrel connector gets really hot! (145 degrees F). In fact, hot enough that the connection seems to expand, then after turning it off and cooling off -- the barrel connector doesn't make contact anymore and i have to wiggle it to make it contact again.
The LED array is 24 Volts @ 2 Amps / 45 watts. The screw-in jack is 24 Volts / 150 Watts rated. The power supply is 24 Volts / 3 Amps rated. The power supply also gets a little warm (140 degrees F) but seems to have no issues otherwise.
So the question is --
- Did i mess something up and created too much resistance in screwing the wires into the terminals?
- Is the screw-in terminal jack i bought of poor quality and just can't handle the current flowing through even though it's rated for 150 watts?
So should I still try to use the screw-in barrel terminals, or am I better off just cutting the power supply barrel plug off and directly soldering the power supply output to the LED array power-in wires?
Thanks!
Thanks!
