I got this broken power supply at an auction a few months ago and I've been making occasional attempts to fix it since.
The lightbulb test revealed that the primary side was charging the main cap properly (one brief flash when turning the PSU on). None of the main rails on the secondary were shorted to ground.
The problem - when turning the main PSU switch on it would drop the 5Vsb line to 0 (it goes from 5 to 0V when measured). The power supply wouldn't start when bridging PSON to ground. Every now and then when turning the switch on it would actually have the 5Vsb rail on but it still wouldn't start. When connecting the PSU to a motherboard that has a standby LED, the LED would immediately turn off in first case (when the PSU loses 5VSB) and it would flicker in second case (when the 5VSB line didn't drop to 0).
After and unsuccessful repair attempt by replacing the 5Vsb IC the problem remained the same.
Fast forward to yesterday, I had some free time to poke it with a multimeter and I noticed a broken diode. The solder mask under it was cracked and separated from the PCB as well.
I don't know the specs of the diode because it doesn't have any markings on it, so I need some help finding a replacement. An electronics store in my country sells this one:
I'll include some pictures of the PCB and the problem area. The diode in question is D103 on the PCB (it was already removed in some of the pictures).
Any info is appreciated.
