Sansui AU9500, capacitor blows
    I have Sansui amplifier AU9500,, no sound, I found fuse 2 amperes, 7 amperes burns, I found too 3.3 uf 100 volts completly bulging under driver board, 1 transistor output 2SA679 shorted,and I found too the 4 capacitors 4700UF 63 volts they have not good value, I changed all these components and one of 2 capacitors 3.3 uf 100 volts is going very hot after 30 seconds, do I have power supply problem?
    Re: Sansui AU9500, capacitor blows
    A 7 ampere fuse burns out, too, when rated for only 2 amperes? Sounds like a bad transistor to me! (besides the bad caps, of course!)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    16 GB AData XPG Spectrix D41
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
      Yes, I change too 2 transistors audio output on the left channel, and same problem the 3.3 uf 100 volts under the driver board become very hot and blowing up
        you put the cap in backwards or the power supply needs work
          The capacitor was completly bulging before I work on the amplifier, I put the cap with good polarity and I put a 160 volts capacitor( original was 100 volts), I think problem is in the Power Supply
            did this amp ever work for you ? a little will be a big help ..
            the only caps i see with 33 is 33pf .
              What are the LOCATION NUMBERS of the componemts that you changed ? Which capacitor is getting hot? C???? For a capacitor to get hot it is either in backwards or has way too much voltage across it.
                hold on a bit .. no way too much voltage got the 100v cap hot . 3.3uf isnt a value in that amp as far as i can see .. if you cant work out board designator id tell us what it connects to . and if there are holes in the board for it . it is possibly a late addition from factory .
                some nice pictures will help .
                  Either something is drawing power like a SOB, or that cap is backwards or wrong value or high ESR.
                    Check on this photo the 2 new capacitors I put, one is blue and the other is black, I check on schematic and is not listed
                      trace where the wires go to what the caps connect to .and tell us ..
                        think i have found the problem .i found an original pic .. look where the blown up one connects to .
                          In one version the caps were .01µf disc caps, and electrolytics in a different version.
                            so did it get fixed or not ?
                              My version is with electrolitic cap and when I change it I verify twice if it's polarity is ok
                                fit it as seen in the pictures .
                                  I check voltage on the 2 electrolytics and it seems normal one gray wire have -49 volts and the other with yellow wire have +49 volts , they connect directly on bridge rectifier, I try to switch on amplifier and I remark distortion on one channel and after 1 minute the capacitor goes very hot
                                    the connections are wrong .. try looking at the pictures we spent time looking for and posting for you .
