HELP BIOS HP-15dy1005nl
    Good day! I try desperately BIOS files for HP 15-DY1005NL. HP has no support for this notebook model. I sneak for your availability.
    Leonardo
    Re: HELP BIOS HP-15dy1005nl
    Leonardo
    post the backup of the original bios
      This is the backup file
        the posted bios is almost empty..remove the bios chip from the motherboard before reading or writing, or glue wires between the bios chip and the programmer..do not use the clip ... what programmer do you use ??
          Unfortunately the chip was damaged! I need to reprogram a new XM25QH128A. I can't find a bios file to use.
          Thank you
            Thank you
            Do you mean its physicaly damaged,like burned or a broken leg ,or damaged because you can`t read anything from the chip. What model is your programmer
              I use RT809F programmer.
                Do you think the chip is damaged because you can`t read anything from it,or is it burnt ,i have asked you already at post #6
                There`s an old thread about this programmer + XMC chip compatibility.You can try updating the software to the latest.
                https://www.badcaps.net/forum/showthread.php?t=80023
                I don`t know if anyone has found a fix. The CH341A supports them with NeoProgrammer and ASProgrammer software.
                  How can I extract this Hp bios file?
                  I need the bin file to reprogram my broken chip.
                  Thank you
                    Thank you
                    If you can`t read anything from it then how are you going to write anything to it.I already asked if the chip is physically damaged.Its important to try and get a good backup from it as it contains the DMI info. The CH341A programmers are cheap,its always good to have more than 1 programmer.
                      The original chip is damaged how do i reprogram a new chip? what bios file do i use?
                        Damaged in what way.........
                          Wrong reprogramming so it is not possible to recover its original content ...
                            Post the laptop serial number .
                              Here`s a link to download the bios updater https://ftp.hp.com/pub/softpaq/sp118...0/sp118345.exe
                              Run the exe on a win 10 PC (the updater crashes on win 7) ,go to the next screen and choose the "Copy" option ,it wil decrypt and extract four different bios. Two of them are 16MB ,086C8.bin and 0864B.bin ,try both.
                              15-dy1xxx Series
                                I tried to download this file but once launched the executable it extracts it but it stops does not give me the choice.
                                15-dy1xxx Series
                                  15-dy1xxx Series
                                  In attach Serial
                                    Extract the sp118345.exe to a folder using 7-zip https://www.7-zip.org/ or winrar. Run the 864B.EXE in the extracted folder, it should give the option to copy now.
                                      In attach Serial
                                      https://partsurfer.hp.com/Search.asp...ext=5CD9527GML
                                      BIOS_VERSION Sku Desc Not Available
                                      IMG_BUILDID BID=19WW2LAT601#SABZ#DABZ
                                      IMG_DESC1 3K6b7K7P7WaBapaqasawbCbhcbdUdpdqfP.QA <-This is the FeatureByte
                                        Here`s both 16MB bios,if you still can`t extract them .Hopefully one of them will work.
