Thread Tools | Display Modes |
#1 |
CertifiedAxhole
City & State: Constanta
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hardcore Geek
![]() Good day folks. I had a look at this soundbar from Panasonic today and it seemed like an easy enough fix, but then I got stuck.
Have a look at that fried primary. I reckon the transistor popped and took out the current sense resistors with it before the fuse could open to cut the power. I thought I'd have a hard time figuring out what values those are, as it usually happens when SMD resistors go up in smoke, but thankfully I was able to clean them enough to read 1r60 on there, which is 1.6ohms, so that was sorted - we need 8 of those. On to the transistor: it's one of those mystery parts that no one's heard of. 14SL70....what could this be ? Ironically, it has a little logo there too, but all searches come out empty. I tried everything, including sourcing a service manual, but that didn't yield any results either....I'm tempted to just dig through my parts bin and pick one out semi-randomly. I'm hoping the control IC survived, because the small passives around it are fine, so I'm hoping something from the FQPF series will work in place of the original one. It claims to be a 120w amp, in case someone wants to suggest something based on past experience, enough to be in the ballpark. As always, thanks for any help. Cheers.
__________________
Wattevah... |
#2 |
![]() Hi
Regards the F E T , you can probably match up another . By the numbering seems to be rated at 14 amp , 700 volt . I don't recognise the manufacturer logo either . I would replace the drive chip also . Doubt it would have survived . Regards Zen |
#3 |
CertifiedAxhole
My Country: Romania
![]() The driver IC is also tough to find info on. I don't have the board in front of me right now, since it's at the office, but we can just about make out the part number in this pic....
I'd say it's MIP034c and below 714c4? (C or 0) - we won't know for sure until I look at it up close, but it doesn't matter because I tried every combination and nothing came up - HATE it when manufacturers do this and somehow manage to source the most obscure parts on the planet ![]() |
#4 |
City & State: london
My Country: uk
I'm a: Knowledge Seeker
![]() Makes thrings very difficult for us , i know .
No schematics ? |
#5 |
CertifiedAxhole
My Country: Romania
![]() No, no schematics.....of course
![]() I tried searching for SU-HTB and indeed found a service manual, but the schematic isn't even close - that one has a separate STBY power supply, even some relays and sh!t. It's for a HTB500. Turns out there IS such a thing as "MIP" series IC, since on page 92 you've got IC5799 which is a mip2f20 which DOES at least return some results on google, as do other searches for "panasonic MIP IC". Meanwhile mine gets nothing... I'll try the transistor+resistors first and if it goes bang again, that's it - tough luck - it's going in the bin.... Last edited by Dannyx; 01-23-2021 at 04:05 PM.. |
#6 |
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
![]() Dannyx
Try this website to see if you can match the device manufacturer https://how-to.fandom.com/wiki/How_t...heir_logos/P-T I do not recognize this manufacturers logo There are no hits on this part number which is very strange most of time you would get something even if it is the wrong device ( but nothing at all weird ) unless it is a house part number Can you determine what the output voltage is by any chance————> I do not know if this will help you or not
__________________
9 PC LCD Monitor 6 LCD Flat Screen TV 30 Desk Top Switching Power Supply 10 Battery Charger Switching Power Supply for Power Tool 6 18v Lithium Battery Power Boards for Tool Battery Packs 1 XBox 360 Switching Power Supply and M Board 25 Servo Drives 220/460 3 Phase 6 De-soldering Station Switching Power Supply 1 Power Supply 1 Dell Mother Board 15 Computer Power Supply 1 HP Printer Supply & Control Board * lighting finished it * These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10% 1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later ) 2 Hem Saw Computer Stack Board All of these had ![]() All of the mosfet that are taken out by bad caps ![]() Last edited by sam_sam_sam; 01-24-2021 at 08:29 PM.. |
#7 | |
CertifiedAxhole
My Country: Romania
![]() Quote:
The output of the supply itself to the amp section could be anywhere between 30v and 60v based on my limited past experience with amps. The amp claims it's 120w...not sure if this is reflected by the transistor's ratings in any way, since it's a SMPS... |
#8 |
CertifiedAxhole
My Country: Romania
![]() I ran a search on Aliexpress and it does actually throw some transistors in there, like 2n60f, so I'm actually curious if they're regarded as equivalents....
There IS such a thing as SL701, but that's a different part entirely.... Last edited by Dannyx; 01-25-2021 at 11:04 AM.. |
#9 |
CertifiedAxhole
My Country: Romania
![]() Ok, I made some more progress on this thing: I actually managed to find the IC: it's a MIP004, when I thought all along the second 0 is a 6, so there IS an official Panasonic datasheet for it here. It's probably dead (Jim
![]() For the FET, I dug through my drawer of transistors and after comparing and contrasting several types, I think I'll go with the P14NK50ZFP. |
#10 |
CertifiedAxhole
My Country: Romania
![]() Ok, I took a shot at powering it up today. I couldn't source a MIP004 anywhere, much less so in SMD form, so I just replaced those resistors and tried it with a lightbulb in series. Ironically, nothing explosive happened: the bulb went dim, but it also produced no output. Measuring the VCC pin of the IC, I can see it jumping between 0 and 19v repeatedly, so this makes me think it's dead and doesn't drive the output....I'm now hoping to be able to replace it with a "FAN" IC by comparing datasheets as much as I can....
Thread Tools | |
Display Modes | |
