LG RZ-32LZ55 Display issues - lines on LCD screen
    I picked up an LG TV from the street recently. The model is RZ-32LZ55. For once the screen was intacted and not smashed but upon plugging it in, it's obvious that it was thrown out because of an issue with the display. As you can see from the pictures, there's sections of display that has lines running through it horizontally and vertically. When I squeeze the top of the TV frame, the lines would slightly shift position but no matter that I do, it's always there. All ribbon cables were connected and clamped down.
    I've connected a PS2 to test and everything else sound and all appears to be working.
    WIthout knowing too much, I presume it's either the screen or the T-Con board (potentially the AV board too?). Is it worth investigating or am I better off stripping off parts to sell on eBay?
    Any guidance as to what to check would be appreciated.
